v-force hp?
Old Jun 26, 2003 | 11:27 PM
  #31
DynoGuy's Avatar
Default v-force hp?
You are right on Thread, on my Dyno we had 37 Hp out of the box (going from memory, it was a couple of weeks ago)with some tunning we got 38-38.5 HP
Old Jun 26, 2003 | 11:41 PM
  #32
DynoGuy's Avatar
Default v-force hp?
There is really no such thing as a Dyno set up for Auto's. The only difference is you need to graph your torq and HP against mile/hour instead of engine RPM. this is because if the clutching is right, the engine will rev almost instantly to peak HP and stay there until shift out. My Dyno show's 37HP on a stock KFX700, same as every one else's that I've heard about.
Old Jun 27, 2003 | 12:07 AM
  #33
KevinM's Avatar
Default v-force hp?
With the way the V responds to a simple primary spring change, I'd say no way is the stock clutching shifting out at peak power. Until someone puts a tach on a V and dials the shiftout in perfectly, I can't see the number being correct.
Old Jun 27, 2003 | 12:50 AM
  #34
DynoGuy's Avatar
Default v-force hp?
Your right Kevin, if the clutching is not on with an auto, your numbers are useless. However the KFX700 clutching is very, very close to perfect stock. The engine goes right to 6400-6500 (at peak HP, going from memory again because I'm not at the shop to check.)It runs close to peak power until shift out.
If you are experiencing better run times by changing the primary spring, it's probably because you are over or under reving (past or below peak HP) and getting better traction.
doggster
Nov 22, 2001 11:32 AM
azelmo
Sep 11, 2001 09:18 PM
azelmo
Jul 13, 2001 03:50 PM
adamnieman
Apr 22, 2001 07:31 PM
ctbanshee
Dec 2, 2000 11:10 PM
