Ford Crew cabs w/7.3 Diesel
#9161
Blame the US. First we blamed them, now they are blaming us.
(Yes, I watched South Park the Movie. I admit it...IT SUCKED @SS!)
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
#9162
Originally posted by: nedflanders
oops, cobalt is the material or style of bit, not a brand name. buy a 3/8" bit, or some other common size from Home Depot. try it out on some thicker/hard metal, and see what you think. IIRC, they also have a small set for under $20. i think one larger size bit is $5-10.
Originally posted by: rescuediver
They have the Cobalt bits at Home Depot, I thought you knew the bits at Harbor Freight (don't remember name) were made by Cobalt, just sold under a different name. You are right, I haven't had any luck with the titanium bits[img]i/expressions/face-icon-small-sad.gif[/img] they stink.
#9163
Originally posted by: ThrashAndCrashUntilItsTrash
that is because ANY bit that is "coated" have junk steel underneath. At one of my jobs I used to take about 500 drill bits a month to a local sharpener, if a bit was coated, he threw them in the trash. In my own use in my garage, the coated ones are the only ones I can afford so they work pretty good, but if you get them hot, trash it!
#9164
i thot i had asked for my old ID back. but if I get a name change, I'd really like canucklehead.
#9165
#9166
Hhmmm, for some reason[img]i/expressions/face-icon-small-confused.gif[/img] cobalt struck me as being a name brand[img]i/expressions/face-icon-small-blush.gif[/img] don't know why[img]i/expressions/face-icon-small-blush.gif[/img][img]i/expressions/face-icon-small-blush.gif[/img]
Ask Irwin
Q: Are Irwin cobalt drill bits coated like the titanium ones? If the cobalt bits are rockwell hardness 66 - 67 HRc, what hardness are the titanium bits? Once you sharpen a cobalt bit and the gold coating is gone, is it just a regular bit?
A: Cobalt bits are not coated, they are cobalt steel through and through. At the end of manufacture a cobalt bit is baked in an oven to turn the surface color of the steel a dull gold color. This is done primarily for easy identification by color. If the gold wears off or is ground off in sharpening on a cobalt bit, it is still solid cobalt steel. Our cobalt drill bits are made of M42 cobalt steel which has 8 percent cobalt content. The Rockwell is approximately 65.5 to 67 Rockwell C. Irwin titanium drill bits have a hardness of approximately 64.5 to 65.5 Rockwell C. The titanium coating is much harder at approximately 82 Rockwell C. If you sharpen a cobalt bit it is still as good as a new bit, assuming it was sharpened correctly. If you sharpen a titanium bit its performance will drop because the coating is gone on the tip; however, you still have the benefit of the titanium coating in the flute of the bit and on the sides of the bit. It will still perform better than a standard bit.
And The More You Know....
#9167
Yep, it's our fault they have poverty, gangs and teenagers with to much time on their hands[img]i/expressions/face-icon-small-blush.gif[/img] As long as they won't admit there is a gang problem[img]i/expressions/face-icon-small-sad.gif[/img] there will always be a gang problem. We went through that years ago, now it's public knowledge WE HAVE A GANG PROBLEM[img]i/expressions/face-icon-small-sad.gif[/img] and along with gangs come problems, including the ones with guns.
#9168
Cobalt is a brand or line of Irwin.
Ask Irwin
And now you know....
Ask Irwin
Aahhhh, it's all starting to make sense[img]i/expressions/face-icon-small-wink.gif[/img] LOL! Thanks for the information[img]i/expressions/face-icon-small-smile.gif[/img]
#9169
Of course they don't realize that "Gun Control" means using both hands. [img]i/expressions/face-icon-small-wink.gif[/img]
#9170
We didn't take any pictures while at the Miami Trails. But we did get some good shots at Carnegie[img]i/expressions/face-icon-small-smile.gif[/img] they should be up shortly[img]i/expressions/face-icon-small-wink.gif[/img]
