Old 12-10-2007, 07:42 PM
JustRandy's Avatar
Default 85 to 88 Suzuki LT230S Quadsport help.
http://www.sprocketspecialists...ts.aspx?txtSearch=464
28-74 teeth! Now that's a selection!
  #1662
Old 12-10-2007, 09:22 PM
PoolGod230's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: JustRandy
Do you know how wide they are? Any other measurements? Mine are 32 inches wide and 24 inches wide where I put my hands (close to the light switches n that).</end quote></div>
Ok so maybe mine aren't wider (also 32in) only rise up 4.5in at highest though
  #1663
Old 12-10-2007, 09:40 PM
mjlar94's Avatar
I have low moose bars, just a temporary fix. I plan on using the same bars I put on my DT. High MSR bars from bike bandit. Under the control menu.
I highly suggest you follow that route, theyre very comfortable and I think you gain like 1in wide, and 2in high.
  #1664
Old 12-10-2007, 09:46 PM
mjlar94's Avatar
I hate to say it but I think the source of the problems is a lean main! On both of our sakes. You said you drilled out something like a 210 or 220 if I remember right?
  #1665
Old 12-10-2007, 09:53 PM
mjlar94's Avatar
Mine will idle fine until i open it up hard. If it fouls out at idle, a whack of the throttle and kicking will take care of it.
My assumption is the air jet. No one ever changes them . Mine has a 1.8 in it and I think it should be more like a .9 or .8. Pilot meters the ammount of air that should enter where as the air jet is metering the air at idle.
  #1666
Old 12-10-2007, 10:25 PM
JustRandy's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: PoolGod230
Ok so maybe mine aren't wider (also 32in) only rise up 4.5in at highest though</end quote></div>
I was thinking wider for a long time, but today I was analyzing everything while turning in circles and I feel like I can't lean enough with my arm stuck way out in front of the quad. And my other arm is tucked into my hip area and I'm gripping the bar backwards with that hand. Ironically, now I'm thinking shorter, lol.
My bars are also 4.5 high and about 1 or 2 inches of pull back.
I might experiment with a hack saw.
  #1667
Old 12-10-2007, 10:31 PM
JustRandy's Avatar
mjlar, did you get the ticking noise figured out?
I've never heard of anyone changing the air jet.... But, I haven't talked to everyone and I dont know it all either, so....
I'm going to install the 10 pilot tonight and see how it works tomorrow. (I still have that #$&^&* oil leak from the valve cover to fix again anyway). My headlight came in the mail today too. Original suzuki box! Cool! So, I have a few good reasons to tear the plastic back off, yet again.
  #1668
Old 12-10-2007, 10:38 PM
JustRandy's Avatar
My main is good. I did the WOT chop and plug was a light tan. My plug looked about like this http://www.dansmc.com/spnorm.jpg
  #1669
Old 12-10-2007, 11:11 PM
mjlar94's Avatar
Where u gettin those jets from?
  #1670
Old 12-11-2007, 12:40 AM
JustRandy's Avatar
The arctic cat dealer.
Quick Reply: 85 to 88 Suzuki LT230S Quadsport help.
