PDA
View Full Version : Polaris Ask an Expert! In fond memory of Old Polaris Tech.
Pages : 1 2 3 4 5 [6] 7 8 9 10 11
  1. 2000 250 trail blazer carb problems
  2. 600 sportsman oil pressure relief stuck
  3. 1998 Polaris Sport 400 BRAKE PROBLEM =[
  4. Polaris 330 Magnum ECM Parts/Repair Info?
  5. engine bogging down
  6. rear shock
  7. predator 500 oil in airbox help!!!!
  8. predator 90 or 50?
  9. radiator fan switch
  10. Polaris 250 Four-Wheel Drive Won't Engage
  11. 92 Trailboss 2x4 gear oil
  12. 02 Sportsman 500 HO stalling in low & reverse?
  13. tires size
  14. Speedometer issue
  15. 2012 polaris 4wd not working
  16. Winch for 2013 500 HO
  17. 1994 Big Boss 400 shift assembly bypass.
  18. Frustrated and Need Help!
  19. Elect problems
  20. 500 x2 no battery power
  21. 1995 Xplorer 400 Polaris Starter
  22. 2010 850 xp esp valve cover gasket blowout
  23. 04 330 magnum starter help
  24. one way clutch bearing
  25. 2000 polaris sportsman 335 no spark
  26. ignition switch
  27. water pump
  28. 99 Xplorer 300 Trouble Starting / Running
  29. 2000 Trail Boss 325 Issues
  30. Can the Polaris Tech help?
  31. Predator 90
  32. whelp im back 94 polaris 400L
  33. weak idle
  34. Trail Boss 250 & Explorer 300
  35. Changing water pump seal..OPT
  36. 2009 polaris sportsman 500 HO overheating
  37. '95 Polaris 400 Starter issue
  38. 300 crank bearings
  39. Top speed
  40. 1994 Polaris 300 4x4 Top End kit advice
  41. Creeping again?
  42. 1997 Trailblazer 250 - No electric start
  43. delayed start
  44. Tires
  45. Maybe the oil cooler wasn't my problem...
  46. Impeler
  47. Trailblazer 250 wined down??
  48. 2006 Sportsman 500 HO EFI
  49. Visco Lok
  50. 99 ranger 500 6x6 no spark till key is switched off
  51. `02 sportsman 500 hard to shift
  52. thermostat
  53. 05 Polaris Phoenix 200 trans isssue
  54. Magnum 425 water pump
  55. breaker
  56. 2004 Ranger
  57. Predator 90 stator question
  58. clutch problems < bike is creeping forward
  59. 2001 500ho carb issues
  60. Oil Cooler Fan Issues
  61. EPS and Check engine light
  62. 2001 sportsman 500 idle fails after steep riding
  63. 2001 sportsman 500 no spark on cold morning
  64. battery died
  65. 1994 Polaris 300 4x4 Oil Pump / Carb lines
  66. 1995 Polaris Scramber / Gearcase Brake / Rear Brakepads
  67. Sportsman 800 vs scrambler500
  68. 2005 Polaris 700 sportsman
  69. tranny oil
  70. Scrambler 400 burning coolant
  71. Opt::
  72. 02 polaris scrambler 500 no spark
  73. 04 Ranger Charging problem?
  74. 2012 Polaris 500 backfires doesnt start
  75. Broken Support Stabiliizer Bar
  76. 2014 Sportsman 570 Touring seat issue's
  77. 425 Mag Tripping Breaker
  78. OPT I need your help!!
  79. 08 Sportsman 800 HO
  80. 2004 Ranger
  81. 96 sportsman 500
  82. currious
  83. 88 Trailboss 250 agony - seeking help from OPT
  84. Belt change 2003 600twin
  85. 06 Sportsman Dying
  86. 1995 Polaris Scrambler 400, no spark then spark on 5 pulls
  87. help !! having awd problems
  88. 2001 Polaris Sportsman 500HO Upgrade Thermal Sensor Harness???
  89. Clutch or Belt
  90. Help needed with logical steps to trace issue
  91. 2010 550xp inermittent "miss"
  92. What to do?
  93. 1994 Polaris Sportsman 4x4 issue
  94. Engine timming 700 twin 02
  95. 06 Sportsman 700 wont shift into reverse unless engine off
  96. 97 scrambler 400 4x4 no start
  97. HELP,Rebuilt a 250 xplorer 2 stroke and wont start, timing problem it seems
  98. 330 4x4
  99. Polaris Xplorer 500 4x4 Issue
  100. 1999 Scrambler 400 2 stroke won't start
  101. Inner CV Joint Troubles
  102. 01 Sportsman crappy shifter ass'y
  103. new speedo kills my engine! 02 Sportsman 500 HO
  104. Carb drain bolt o-ring
  105. Sportsman 335 / 400 jetting
  106. oil change question
  107. pressure tester
  108. `02 sportsman 500 ho belt drag
  109. '01 500 engine fit a '00 400 chassis
  110. 2014 400HO...OVERHEATED ? fuse location?
  111. 2005 Ranger XP no electrical power
  112. Scrambler 400 backfires wont start
  113. 2001 Polaris Srcambler 400 wont start
  114. 2014 oil tank vent..slit ? Wtf
  115. 2002 sportsman 700 stuck in low gear
  116. opt...MAYBE you up for another one????
  117. 300 4x4 barn find oil pump Drive stuck
  118. Polaris Missing water pump impeller
  119. 2002 sportsman 500 bogging down
  120. Left front caliper needs to be rebuilt?
  121. 2000 Sportsman 500 fuel leak
  122. Tire and Rim swap
  123. Hey Stendori (front spacer post)
  124. '98 magnum 425 awd button affecting spark
  125. 2005 sportsman 90 cutting out
  126. Help with 1998 Polaris Sportsman 500 Speedo
  127. Speedometer repair/replace
  128. '01 500HO Brake lever..broken in crash
  129. 95 Polaris 4x4 400
  130. electrical problem
  131. coolant squirting out over flow tank?
  132. no hi-beam,speedo light,gear ind. light
  133. Noise in the head and sloppy cam
  134. 1998 Polaris Trailblazer 250 Will Not Crank
  135. bst40 carburetor
  136. Odd Issue on my 06 Sportsman 500EFI
  137. 2005 sportsman 800 help
  138. front spring crunching?
  139. Shredded belt on trail replaced with OEM now creeping
  140. throttle cable help
  141. Yet another speedo / AWD issue
  142. 2000 Sportsman 500 gear selector body problem
  143. Sportsman Front Axle Instalation
  144. '07 Sportsman 700 EFI dies but will restart - The sequel
  145. Sportsman Polaris stuck in reverse
  146. recommendation
  147. opt need help with 94 polaris 400L 2 stroke
  148. centralized hilliard
  149. Sportsman 500 showing signs of worn cam but cam is ok.
  150. Tach Not Working
  151. 97 Magnum 4x4 425
  152. 07 Yamaha Kodiak 450
  153. popping noise
  154. '01 Sportsman 400 mechanic help needed
  155. Chain came off 2003 Polaris Trailblazer 400
  156. Polaris sportsman axle
  157. 2005 Sportsman 800
  158. 2006 polaris sportsman 500 x2
  159. fusible link blew...replaced an blew again
  160. dead atv
  161. 03 Polaris Trailblazer 250, Lack of Up Hill Power
  162. Problem with front cv boot
  163. yamaha kodiak wont run on gas
  164. 96 Sportsman 500 rear brake noise
  165. 1994 Polaris 400l 2x4
  166. 1997 polaris big boss 400: stator plate screws stripped
  167. test/replace hub coil
  168. Limiting speed for child safety???
  169. 99 Sportsman 500 high rpm awd engagement
  170. engine braking
  171. 2002 Sportsman 500 keeps shutting down
  172. 1991 Polaris Trailboss 250 (4x4)
  173. 02 Magnum Ball Joints
  174. 2014 Sportsman 570
  175. 2002 500 Sportsman belt alignment
  176. 1999 Sportsman 500 stumbles at mid-range
  177. Polaris sport 400
  178. 2003 Polaris 330 cranks but wont start
  179. 700 Sportsman, ugh!
  180. 2002 Sportsman 500 HO performance issues.
  181. 2001 scrambler 400 Need Help!!
  182. broken weld bottom of strut at oil cooler
  183. 1999 Polaris Sportsman 500 no start
  184. No Electrical power 2001 polaris magnum 325
  185. Duplicate posts!
  186. Sportsman Front Differential Problem
  187. 98/99 sp500-Top end only 54mph and sounds like it's kinda winding out
  188. 99 Scrambler 400: Oil Injector Block Off Necessary?
  189. Phoenix tire question
  190. Scrambler 500 charging issue
  191. 1998 Polaris sportsman 500 fan
  192. Polaris Sportsman 90 - Starts w Starting Fluid then shuts down
  193. Please help OPT!
  194. rewind a pull starter
  195. Changing head gasket
  196. output shaft bearing and sprocket removal
  197. 2000 polaris 400 4x4 axle problem
  198. Need help!!!!!!
  199. 2008 ranger 500 stator
  200. 2009 Sportsman 90 - Lots of Oil in Stator Case - Is it Normal ???
  201. 99 sportsman 500-choke cable
  202. 2005 sportsman - need new battery
  203. sportsman 500 carb problem-sputtering
  204. Mystery Squeak
  205. Bogging issue
  206. 400 2 stroke cdi box going bad
  207. 2002 Polaris sportsman 700 coolant leak
  208. leak
  209. drive belt replacement
  210. sportsman 500 2002 6x6
  211. 1995 polaris 300 4x4
  212. 2002.5 sportsman 700
  213. 2009 polaris sportsman 500 h/o
  214. No power 96 sportsman 500
  215. need advice
  216. Speedo Odo not working
  217. 2004 magnum 330 polaris
  218. Predator 90 Reverse kit
  219. '03 700 won't idle unless choked
  220. Strange, strange idle problem 800 efi
  221. Fan switch sp 500 HO
  222. I'm a Douchie
  223. 97 Trail Boss 250
  224. Sportsman brake change
  225. no spark
  226. 1999 Magnum coolant direction
  227. 2008 sportsman 500 battery light
  228. SP 500 ho no dash lights and no ignition power
  229. Oil in the airbox 850 XP?
  230. ?Using a Tube in a Polaris Tire. Advisable?
  231. Problem with '96 Sportsman 335
  232. 2002 Magnum 325 cuts out lacks power help!
  233. 95 Xplorer Sprocket Change
  234. 4wd....
  235. Brake line fittings
  236. 2012 500 HO sportsman won't idle.
  237. Polaris 500 New belt slipping
  238. Recoil pull start on sportsman 400
  239. 2006 pheonix starting problems
  240. sportsman 400, 2005 solenoid?
  241. polaris srambler loose solenoid in axle hub?
  242. Polaris 400
  243. 2005 polaris trailblazer
  244. Trailblazer engine swap
  245. 2004 Polaris ATP 4*4
  246. 2007 Sportsman 450 Oil Tank Blew Apart
  247. 1992 polaris 250 4x4/4x4 not working?
  248. 2004 Polaris 700 Overheating after trying many many things...
  249. 02 polaris 500 sportsman cooling fan
  250. polaris trailboss xplorer engines
