PDA
View Full Version : Polaris Ask an Expert! In fond memory of Old Polaris Tech.
Pages : 1 [2] 3 4 5 6 7 8 9 10 11
  1. 2009 500x2
  2. wont rev all the way up (02 sportsman 700)
  3. 2 stroke blowing smoke
  4. 02 sportsman 700 running poorly
  5. sportsman 700 cam
  6. 2014 Polaris 570 Touring Gas gage flashing
  7. 2002 sportsman 700 capacitor coil
  8. 05 sportsman 700 slow crank
  9. 2014 polaris sportsman 500 h.o carb
  10. '02 700 running poorly
  11. Choke Cable adjutment 250 Traiil Boss
  12. 2004 Sportsman 700
  13. My long, arduous journey with the Sportsman 800 EFI
  14. Find year of xplorer 400 with sr# 0050905
  15. 02 sportsman bogs at half throttle
  16. Sport 400 clutches
  17. 2002 Polaris Sportsman HO coolant issue
  18. Rearend slipping on 325 magnum
  19. Breathing new life into a 2003 Sportsman 400
  20. Help, need shift shaft - Xpedition 425 4x4
  21. Stops Running
  22. Polaris ranger 400 going dead on me . . .
  23. '02 700 carb diaphragm spring
  24. 2004 Polaris Sportsman 400 dead, no power anywhere
  25. can't get off idle
  26. 2000 trailblazer 250
  27. Awd not working, Polaris sportsman 700
  28. Backfiring in reverse...
  29. Cvt belt slapping a hole in inner and outer covers
  30. 1996 polaris 400 sport 2 stroke wont start
  31. Overheating Question
  32. 2011 sportsman 550 clunk while turning
  33. 1994 Polaris trail blazer isles fine but won’t take throttle
  34. My Polaris Trail Boss can only pull start and have no lights.
  35. VIN location
  36. 2007 Sportsman X2 800
  37. 1986 polaris trail boss 250
  38. polaris sportsman 335 4x4 wiring issues
  39. where is the TBAP located on a polaris ranger 700xp
  40. 2003 Sportsman 700 Speedometer problem
  41. 94 Polaris 300 4x4 compression problems
  42. 2001 polaris scrambler backfiring, killing 1 mile from house.
  43. 2010 polairs sportsman 500 ho
  44. oem speedometer install on 01 trailblazer 250
  45. 2004(?) atp 330 no spark or power at cdi
  46. 2005 Polaris Sportsman 700 twin EFI died
  47. 2004.5 Sportsman 400 AWD / wiring issue?
  48. Best way to clean engine after blown head gasket
  49. 2008 500
  50. sportsman 700
  51. 2000 Polaris Magnum 325 Rear axle bearings
  52. 1994 Polaris 400 sportsman 2 stroke
  53. 05 polaris predator 500
  54. Sportsman Stator ground wire placement ?
  55. 2007 Sportsman 500 EFI primary clutch spring
  56. 2014 400HO. "misses" at 4500 rpm
  57. 2003 Sportsman 500 HO not starting (turns over not firing)
  58. 1998 Scrambler 500 No Spark
  59. 2013 Polaris Sportsman 500 HO Backfired and now will not run
  60. 2007 polaris sportsman ho 500 efi
  61. Electrical gremlin ARRRGHHHHHH
  62. 2002 Polaris 700 Sportsman Carb Problem
  63. oil change and consumption
  64. 2000 trail boss 325 cutting out at flag throttle
  65. 2006 polaris hawkeye 300 4 x 4 engine oil
  66. 2002 700 twin fault codes
  67. 330 magnum charging
  68. 330 magnum charging
  69. 96 250 Compression
  70. Flywheel
  71. Brushguard for 2004 polaris 700 sportsman efi
  72. 500 carb on a 400
  73. 1996 polaris xpress 400L 2 stroke hi idle
  74. 2006 Polaris 500 H.O Slectric System DEAD
  75. Rear Differential?
  76. 700 polaris 2002 sportsman 700
  77. Polaris
  78. 2005 sportsman 700EFI issue
  79. Difference in Sportsman
  80. 2000 xplorer 2 stroke engine cutting out and in
  81. No reverse.... and few other issues 2003 Trail Boss
  82. 1998 Magnum 425 Recoil Oil
  83. Backfire
  84. 2011 Polaris RZR 800 ticking
  85. 2006 scrambler coolant level...
  86. 2007 sportsman 500 X2 efi crank position sensor
  87. Throttle Cable Position
  88. 2001 Polaris Scrambler 500 4x4 Issue
  89. Polaris explorer300 drive tran
  90. Replaced carb on 96 Sportsman 500, now will not start
  91. Why would my 2005 polaris sportsman 700 be stuck in 4wd?
  92. Polaris predator 50
  93. Polaris predator 50
  94. 2017 rzr 570 starting problems.
  95. 1986 trailboss 250r/es HELP!
  96. 2000 Polaris xpedition 425
  97. rear differential
  98. no power on 2006 Polaris Predator 90 CC
  99. 99 polaris sportsman gear selector help
  100. clutch removal tool fitment?
  101. Jopa07
  102. Stopped moving
  103. Electric gremlin
  104. Central Hilliard or 2 hub Hilliards?
  105. 2003 Sportsman 700 Brake Performance
  106. 2008 x2 500efi cranking issue
  107. 2008 polaris sportsman 800 twin efi awd issue
  108. 99 Polaris Xplorer 400 carburetor issues?
  109. rear size tire on 2002 sportsman
  110. carburator issues
  111. Struggling to bleed brakes
  112. Polaris Predator 90 cc back brake issue
  113. 2007 Polaris ranger 700
  114. 2007 Polaris ranger
  115. 2017 vs 2018 850 high lifter
  116. 2005 sportsman 500
  117. Another counterbalance thread...
  118. 05' ATP 500 fault codes
  119. 2016 Sportsman 570 Backfires & DIES. Has gas. Ideas??
  120. Sportsman 335 wont rev. Please help
  121. 2004 sportsman 500 H.O
  122. 1997 Polaris Trail Blazer 250 not starting
  123. Polaris scrambler 400 4x4 boging
  124. slip on exhaust
  125. 2000 Scrambler 500 Need Help
  126. Polaris Magnum 425
  127. 1999 Xpress 300 4x2- Transmission had a bad day
  128. 2010 Polaris sportsman 500 rear brake cylinder
  129. 1996 magnum 425 gear selector
  130. 2005 Polaris Sportsman 800 EFI fuel assembly
  131. starter sometimes engages and sometimes just spins
  132. 04-05 ATP engine swap
  133. Lateral Play in (Solid) Rear Axle
  134. Help separating rear axle sportsman 500 1998
  135. 2004 Polaris 600 Twin Issues
  136. Need tire help with my Polaris 850 XP.
  137. 06 sportsman awd engages when in 2wd
  138. Polaris Predator 500 turns off
  139. 2003 scrambler 500 front hubs/struts
  140. Polaris 3500lb winch issue
  141. 06 Sportsman 800 stumble
  142. Polaris 425 slow to return to idle
  143. Polaris predator issues
  144. 1998 500 polaris sportsman
  145. No spark with key
  146. '12 trans fit in a '10 550x2?
  147. 2012 550 Sportsman EPS
  148. 2000 Polaris 425 will not rev up!
  149. Help finding a xpedition part
  150. 04' Sportsman 700 twin carb. Model
  151. Magnum 325 static compression
  152. 2000 polaris sportsman 500 running rich
  153. Polaris 400 scrambler running rich through the mid range
  154. POLARIS 425 4x4 Xpedition
  155. Electric start help!!
  156. I Yes my speedometer quit working my top main headlight 4x4 quit working in my
  157. 2008 Sportsman 500 not shifting smooth
  158. 97 trailblazer - help pleaseee
  159. 2000 Polaris Xpedition 425
  160. 2002 700 sportsman
  161. Questions about predator 500 I just purchased for my son
  162. 96 sportsman airbox
  163. 97 xplorer 300 oil injector getting air in line between pump and carb
  164. Stored both my ACE 570s without touching the batteries.
  165. 1999 sportsman overheating
  166. 2008 Sportsman X2 800 Twin no start
  167. 2000 Polaris Sportsman 500 4x4- Battery draining with winch/snowplow use..
  168. 1999 Magnum 500 Gear Selector O-Ring
  169. 05 ATP 500 electrical issues
  170. Polaris Glacier 1 plow system
  171. lean fuel symptoms
  172. water pump seal replacement
  173. Oil Pressure Relief Valve
  174. 2004 atp stator testing
  175. Polaris sportsman
  176. Polaris Magnum 425 Misfiring badly
  177. 1996 polaris sportsman 500 clutching issues
  178. Parts swap
  179. Motor swap
  180. won't get spark
  181. 2007 Sportsman 90 running issues
  182. Awd doesn't engage
  183. Awd doesn't engage
  184. help with this connector
  185. Black CDI wire disconnected, battery won't charge
  186. Poor Running
  187. 2013 Polaris Sportsman 500 -rusted exhaust
  188. compare 2009 to a 2012 polaris 850xp
  189. No start issue.. Tried everything..
  190. Wiring Question
  191. 1996 400 xplorer
  192. 2001 Sportsman 500 ho no start when hot
  193. 98 sportsman 500 awd
  194. 2007 sportsman 500 drive belt????
  195. 06 sportsman eps question
  196. 1994 Polaris Xplorer 300 4x4 Transmission change???
  197. Could someone teach me on a polaris ATV
  198. 2005 Polaris Sportsman 700 EFI rough idle
  199. polaris 500 sportsman EFi
  200. Predator 90
  201. No spark condition 1999 Sportsman 500 w/ ebs
  202. Grip and thumb heaters
  203. 95 polaris xplorer 400 over fueling / smoking horribly
  204. turf mode switch
  205. 2003 Polaris 700 carb, bogging at full throttle
  206. 2009 Sportsman 500
  207. 2008 Sportsman 800 H.O. 4X4 Issues
  208. Keep adding coolant
  209. Throttle Body
  210. 97 Polaris sport 400 no spark
  211. 2003 Trail Boss 330
  212. 03 sp700 with coolant in the oil
  213. variable low speed limiter
  214. 2004 ATP front gearcase
  215. 1998 Sportsman HO with no spark
  216. CV shafts
  217. Front Axle CVJ Boot Confusion
  218. Polaris 2001 Carburetor Problem? Help
  219. Are my clutches out of alignment?
  220. 2004 330 Magnum 4x4 no power after idle
  221. Darn electrical problem with 09 Polaris 800 X2
  222. 2004 330 valve cover oil leak
  223. Does this need to be replaced to get fuel to flow?
  224. how do I install a generic back seat on the 800 sportman?
  225. High idle and creeping/hard shifting
  226. 04 700 Twin EFI trouble
  227. locking in gear when hot...
  228. Predator 90 new CDI and Coil NO SPARK. HELP!
  229. 2001 Polaris sportsman 500 HO engine fan and bogs at high throttle
  230. 2005 sportsman 700 starting problem
  231. Can’t stop running rich
  232. Frustrated...Need help
  233. New oil seal leaking at weep hole
  234. Brakes
  235. Still over my head
  236. What is this above the oil filter?
  237. 2004 Polaris 700 efi
  238. Strange electrical issue 2007 Sportsman 500 HO EFI
  239. 2005 sportsman 500 electrical pain in the a!!
  240. Sportsman won't start
  241. 00 Magnum 500 no spark, I have tried everything I know
  242. 2001 Sportsman 500 ho no start
  243. Couple questions and advice for the new guy
  244. rear end grinding noise
  245. 2002 Magnum 325 Rear Wheels wont Turn
  246. 2000 Xplorer 400 4 x 4 this one goes out to OPT
  247. Sportsman 500 Seems Starved for Fuel
  248. 5134206 carrier housing
  249. 2002 Polaris scrambler 400 2x4
  250. Shift lever sticking
