PDA
View Full Version : Polaris Ask an Expert! In fond memory of Old Polaris Tech.
Pages : 1 2 3 4 5 6 7 8 9 [10] 11
  1. 2001 Sportsman 500HO wont start
  2. rear gear fluid
  3. 96 sportsman 400 starter question
  4. 2006 Polaris Saw Tooth no power
  5. my shifter shaft is broken n i wanted to know is it hard to replace n what is the pau
  6. Need Help With Reverse Gear!
  7. 96 sportsman 500 won't stay started
  8. HELP!! 2002 sportsman 700 speedometer issue
  9. 2000 Polaris Expedition 4wd problems
  10. Demand Drive Plus Fluid
  11. Xplorer 300 - Front Diff ?
  12. Xplorer 300 Questions from Newbie
  13. 2001 magnum 325 2x4/trail boss
  14. Electric Start Issues Please Help!!
  15. polaris 335 sportsman propellershaft removal
  16. 600 rod bearing
  17. New Brakes, but still not working.
  18. 2006 700 efi sportsman won't start when below 20
  19. The Site's Main Page
  20. 1996 sportsman 400 4x4 2 stroke carb problem
  21. 500 HO full time 4wd
  22. Old Trail Boss 250
  23. polaris 500 no AWD
  24. 2000 scrambler 500 4x4
  25. 1998 Explorer 400L
  26. My 1990 Polaris keeps shutting down!
  27. 2007 Polaris 500EFI Dead/ECU?
  28. hello... new member 97 scrambler 400 carb backfire???
  29. No power 2006 Polaris Sawtooth
  30. 2010 Sportsman 550 xp w/Glacier Plow
  31. Reverse kit ?'s, 03 Pred. 90
  32. 2006 Polaris sportsman 700 EFI shutting off
  33. 1998 polaris sportsman 500 4wd wont engage
  34. 99 Sportsman 335 Stator Replacement
  35. rough idle
  36. 425 xpedition questions
  37. Hello, new member. 06 Sportsman 90 questions
  38. Carb to EFI
  39. atf in hubs
  40. 1999 Sportsman 500 issue
  41. polaris Hawkeye no spark...please help diagnose..
  42. 07 hawkeye
  43. 2000 polaris 250 trailblazer
  44. 2006 Polaris Sportsman 500 X2
  45. Help??
  46. 2008 sportsman 800 Over heating
  47. Polaris 850 xp issue
  48. new knocking sound 96 400 L motor sport
  49. polaris brush guard!
  50. Strut ball joint, removal and install?
  51. 2001 scrambler 90 no spark
  52. 04 700 Front drive shaft popping out of gearcase
  53. 2010 Sportsman 550 Factory installed wench
  54. govener on 01 335??? help
  55. polaris sportsman 500 2004 wont start
  56. 2005 700 EFI sputters and dies
  57. 97 Polaris Sport 400L 2x4
  58. Polaris Trailblazer 2000 problems
  59. 96 scrambler 400
  60. hand warmers kit hook up Polaris Scrambler 500
  61. 1995 300 4x4 chraging problems
  62. cyl torque spec
  63. ATV newbie needs help with Trailblazer 250
  64. running rough
  65. 1999 polaris explorer
  66. 425 xpedition
  67. winch for 1996 sportsman 500
  68. Sportsman 700 primary clutch
  69. 2004 500 sportsman starting/running problem
  70. 99 Polaris Sportsman 500 Starting Problem
  71. 4x4 not engaging after rebuild
  72. Adding pull start to Sportsman 700
  73. 2000 Polaris sportsman 500 plastic pieces found in clutch case s
  74. 2003 Trail Boss slipping/grinding noise
  75. How do I remove the recoil reel on 2003 Polaris TB
  76. Engine Swap
  77. 08 Sportsman 4 wheel drive?? Problem
  78. 04 Polaris Sportsman fires only once
  79. light part numbers for a polaris sportsman 500
  80. 1998 trailblazer pinging?
  81. AWD in reverse
  82. 2001 Sportsman 500HO Carb Rebuild Kit ??
  83. Wiring Mile Mark winch help
  84. 09 Polaris 800 Stalling
  85. 04.5 sportsman awd not working
  86. 2005 predator 50
  87. 2003 90 polaris prediter
  88. little problem
  89. Compatible Antifreeze
  90. low beam lights went out + others, HELP, some things work
  91. polaris 90 scrambler
  92. How hot does a Scrambler 500 HO exhaust get
  93. 2011 Razor over heating problem
  94. 2000 polaris scrambler 400 clutch hitting outside cover any ideas?
  95. polaris trailblazer 250 2003 model
  96. 95 polaris 425 mag,drops all of its oil
  97. magnum 325 cant find low gear
  98. 05 700 efi overheats / fan will not run
  99. Polaris sportsman 500 4WD Battery Shorted
  100. Eng problem
  101. 2003 trail boss carb adjustment?
  102. 2005 polaris phoenix problems
  103. 2004 Polaris Sportsman 600 - need help!
  104. In search of lift kit
  105. Polaris 400 stalls when throttling up
  106. Rear drive shaft repair
  107. hawkeye hard starting
  108. 2005 Trailboss Backfiring
  109. Need help with 2005 Polaris Phoenix vacuum lines in front of carb where do they go?
  110. 99 polaris 335 - 2 stators in 30 min
  111. 250 explorer 4x4 starter
  112. 06 Sportsman 450 Browning Edition wont start?
  113. gear oil on rear axle on 2005 Sportsman 700 efi
  114. 2008 polaris RZR 800 backfires
  115. 2001 Trailblazer 250 Won't start.
  116. 06 polares sportsman 450
  117. 90 polaris trailblazer 250 2x4 seat
  118. 2007 450 sportsman high idle after rewire!!!!!!!
  119. 96 sportsman 400 trans stuck in reverse
  120. '07 Polaris Phoenix 200 CVT+ Gearbox
  121. 1996 Polaris Magnum 425 2x4
  122. polaris 400
  123. How do I rebuild the carburator on a 2000 Polaris Trailblazer 250
  124. Votage Regulator Replacement '01 Sportsman
  125. need help with 2006 polaris trail boss
  126. polaris 800
  127. too much grease in fitting in 700 EFI driveshaft
  128. 1996 polaris xplorer 400 2 stroke question
  129. '01 Sportsman 400 gas leak
  130. 2001 polaris sportsman 90 how does electric choke work
  131. Phoneix problems
  132. changing fuel filter on 2005 700 EFI
  133. Clutch belts
  134. Jet kit
  135. Xplorer 300 Carb question
  136. curcuit board 93 trailboss
  137. Dies, Idles Fast, Runs Fine, Dies, (repeat)
  138. brake light switch
  139. brake light switch
  140. 87 polaris trail boss 250 i need help
  141. 2011 sportsman 500 drain tubes
  142. No SPARK on my 04 predator
  143. 425 Magnum four wheel drive issue
  144. 98 Polaris xplorer 400 belt deflection problem
  145. voltage problems
  146. Belt for 2002 Trail Boss 325
  147. 2008 800 efi HO fuel pump issue
  148. Gas in the oil of my '99 sportsman 500
  149. 2005 Phoneix problems
  150. Need a new radiator for my 2008 sportsman 800 h.o
  151. Lower a-arm bushings
  152. dead battery
  153. '09 Sportsman 550XP Shifter STICKS
  154. 03 sportsman 700 stator has no voltage
  155. 97 Xplorer 500
  156. 2009 Sportsman 500 EFI misses in midrange
  157. T-Bap sensor check??
  158. Black dust in air box.
  159. 1999 Polaris Trailblazer 250
  160. 2000 Polaris Sportsman 500 Non-HO
  161. Trailblazer250 Help
  162. CV Joint - Please help.
  163. TPS sensor adjustment on a 2007 Sportsman 800
  164. 1999 Polairs 400 - won't start
  165. 2005 Polaris ranger 700xp chattering/vibration
  166. Purchasing a ranger xp have ''question''
  167. polaris 500 wont start clicks until battery is unhooked
  168. 07 500 efi electrical problems
  169. Polaris hawkeye
  170. washed my atv
  171. Alignment Issue
  172. 08 sportsman 700 losing power periodically
  173. Polaris Sportsman 400 overheats
  174. 06 800 efi
  175. 1987 trail boss 4x4 barly moves unless your mid throttle
  176. OEM frame mount for polaris plow 99 Sportsman 500
  177. 2000 Polaris sportsman 500, top speed 35 mph
  178. really stuck axle on 2005 Sportsman
  179. 1997 Xplorer 500 rear drive
  180. !998 Explorer 400
  181. Oil Cap Blew, PLEASE HELP
  182. 500 sp efi no start. just click click......
  183. 800 sportsman clutching
  184. 2008 Sprotsman 800 overheating?
  185. "06" 500 HO wont run?!?!?
  186. 1999 Sportsman 500
  187. Polaris Phoenix 200 clutch issue
  188. 1996 scrambler 400
  189. polaris sportsmen wont go over 40 mph idles good low end power good
  190. Polaris gas cap
  191. My first ATV. Polaris 500
  192. polaris backfires spits and sputtersi ha
  193. 2000 sportsman brake problem. A
  194. carb problem
  195. Ignition problem-- help OPT
  196. Troubles putting on rear caliper/rotor/sprocket
  197. 2004 1/2 700 EFI Losing Power after warming up
  198. Isolate 4x4 & posi-traction
  199. Sportsman 400HO running hot, Tires???
  200. Trailboss 330 loses power and backfires
  201. circuit breaker
  202. 05 400 sport awd
  203. polaris trailboss 325
  204. 1996 scrambler 400 2 stroke motor
  205. 2002 sportsman 700 starting problems
  206. atv cover bearing
  207. 2006 700 sportsman runs /stalls
  208. 2002 Sportsman 500 Radiator Cap
  209. Trail Boss 250 (4x4) 1992 brake master cylinder
  210. 2002 500 Sportsman - Fan won't come on
  211. No 4wd after i changed front axle on a 1998 sportsman 500
  212. explorer 300
  213. TrailBoss 325 Jumping out of gear
  214. 1999 Polaris Sportsman 500 rear carrier housing
  215. Coolant for 2010 Polaris Ranger
  216. Charging Problem only on Hot Days?
  217. sportsmen 850xp w/eps
  218. 1996 polaris sportsman 500
  219. 2004 Polaris ATP 330 Troubles.
  220. trail boss not revving correctly
  221. 2002 sportsman 500
  222. 330 atp, ecm ?
  223. To Drain a Radiator.....
  224. Polaris 700 Getting HOT warning
  225. 2006 SP 4wd none in reverse
  226. 95 xplorer 400 no spark
  227. New member&new owner with question
  228. 2006 Sportsman 500 X2 no spark
  229. Polaris Hawkeye no display and won't crank (but headlights work)
  230. Fuel overflow only when running
  231. 86 250 trail boss won't start
  232. 95 Polaris 300 express
  233. Help!!
  234. Explorer 400 Fuel Flow Problem
  235. Gettn agrivated
  236. CV Joint in, but on to the next issue.
  237. 20 Hour Oil Change
  238. new to site, have a problem with atv
  239. 94 Sport 400
  240. 2007 sportsman 500 efi rearend
  241. AWD Engages In 2WD
  242. Lift Kit - CV Joint Issue
  243. 2004 polaris predator????
  244. Polaris Razor Stock Tires??
  245. 2006 polaris hawkeye 300 4 x 4 engine oil
  246. 2007 Sportsman 800 EFI Questions
  247. Polaris 325 4x4 Magnum Problems
  248. 2W-50 Oil
  249. 2003 Sportsman 700 issues
  250. Help sportsman 600 headlight killing insturment cluster
