PDA
View Full Version : Polaris Ask an Expert! In fond memory of Old Polaris Tech.
Pages : 1 2 [3] 4 5 6 7 8 9 10 11
  1. Polaris Magnum 2000 - Help getting it started
  2. Will a xpedition 425 shift drum fit a xpedition 325
  3. Scrambler 2wd steering bushing
  4. Oil & Fluids questions
  5. Polaris wont start unless jumped
  6. Need a little help diagnosing AWD
  7. 4 wheel drive
  8. Top end rebuild 1999 polaris magnum 500
  9. sandy12
  10. sandy12
  11. 2011 Polaris Sportsman XP Wont Start Please Help
  12. help ,2005 sportsman 700 twin not efi fan not cycling
  13. 1998 Polaris Xplorer 300 won't make power
  14. Speedometer stuck on wrong side of pin
  15. Lower Steering Bushing Replacement??
  16. Intermittent winch question
  17. 2012 polaris 850 xp 520194-7
  18. 2003 Polaris trail boss 330 won't crank or spark
  19. 1987 trail boss 4x4 rear brake pad retaining pin removal
  20. Blown up diff in 2012 Polaris 850!
  21. 1999 Polaris Sportsman 335
  22. Polaris 350L water pump seals installation
  23. Polaris Twin 700 efi 2004 after harness replacement code 45
  24. 2001 Sportsman 400 Fine in Reverse, not so good in Forward
  25. 1992 Polaris Sportsman smoking.
  26. 1996 425 magnum 4x4- cooling fan
  27. 93 Polaris 250 2x4 Wiring diagram needed
  28. 1994 Polaris Sportsman 400
  29. Polaris error code caused by throttle freeplay
  30. 2001 xpedition 325 starter solenoid help
  31. Polaris Predator 500
  32. Polaris Predator 500
  33. 2015 Sportsman 570 Problem
  34. 2000 325 Polaris Trailboss
  35. Ring gap
  36. 2002 Sportman 500 HO
  37. Looking for opinions from the Experts!
  38. stator plate swap
  39. 2002 Polaris Magnum 325 No electrical power
  40. 2000 Polaris Magnum 500 rear monoshock problem
  41. Missing radiator fluid
  42. New to polaris
  43. Polaris 300 4x4 explorer 1996
  44. 02 Polaris Sportsman 700 dies when warms up!
  45. Predator 500 Aftermarket Front Shock
  46. 2005 Trailblazer, hole in crankcase?
  47. 1997 Polaris Xplorer 400 HELP - Pops out of reverse!
  48. 99 Xpress 300 crankcase drain screw broke
  49. 2013 sportsman 500 HO saying engine is overheating,
  50. 2004 Polaris ATP 500 fan issues
  51. 2004 Polaris 330 Magnum 4x4
  52. 01 Sportsman lunges backwards and dies when shifting
  53. 2005 Ranger 500 awd problems
  54. New owner of a 2002 sportsman 700 and need help witha few questions
  55. Need help. 05 Phoenix 200
  56. 2005 Polaris Phoenix questions
  57. Polaris clutch plates
  58. 07 Sportsman 500 X2 EFI won't fire...
  59. Not sure about this new axle - advice?
  60. won't idle has code
  61. Won't start just turns over
  62. "Rrrrrrrr" sound
  63. 2015 Polaris RZR 900s - not charging
  64. 1991 Polaris Trail boss 250 4 x 4
  65. Need help with my 91 trail boss 250 4x4
  66. 2002 Polaris Sportsman 700 battery indicator flashing when fan kicks in and lights ar
  67. No spark Polaris Ranger
  68. 2000 Xpedition 425
  69. 2017 850 HL Power Steering Kit
  70. 2017 850 HL Power Steering Kit
  71. 2002 Polaris Magnum No Top End Bogging at Full Throttel
  72. 1995 Xplorer 400 Starter Switch and General Maintenance
  73. Bellcrank shift arm keeps braking
  74. 1996 magnum 435 no spark
  75. Trouble with tracking Trailboss
  76. 1999 Polaris Scrambler 400 4X4
  77. Polaris predator 500 not firing a spark
  78. Ball joint Polaris trailblazer 250
  79. Trailblazer 250 ball joint
  80. 1995 sportsman 4x4 help
  81. 1995 Polaris Scrambler 400 Front Sprocket Replacement
  82. 04 sportsman 700 keeps dying out....???
  83. 2002 Sportsman 500HO tranmission swap.
  84. 1988 Polaris trail boss electric start issue
  85. 2005 Polaris Predator 500 Battery Overcharging
  86. 2000 polaris sportsman 500
  87. 2002 Polaris 325 Mgnaum Freedom Does not start without headlights being on.
  88. SurePower Protection Mode? 2008 Scrambler 500
  89. 2007 Polaris Trail Boss 330 Won't Idle
  90. Check engine light
  91. 2007 Polaris Sportsman 500 EFI Secondary Clutch Spun Off
  92. 2005 Sportsman 500 HO Timing/Running Not Great
  93. Melted awd hub wiring
  94. 2002 Polaris Magnum 325 Cold idle problems
  95. Looking For Polaris Outlaw 50 Wiring Diagram
  96. 2006 Polaris Sportsman 500 EFI
  97. 99 scrambler 500 ignition fix
  98. 2004 Polaris scrambler 500 H.O
  99. Outlaw 525 hole in head cover
  100. 2001 sportsman 500 ho
  101. 2006 x2 500 polaris
  102. 2012 sportsman 500HO running rich??
  103. 2012 sportsman 500HO running rich??
  104. 96 Polaris magnum 425 bogs with air box on
  105. Scrambler 400 clutch question
  106. 91 Trailboss 250 Rear Brake Caliper Rebuild
  107. Need help idk much about these
  108. 2001 polaris sportsman 500HO
  109. 2004 polaris sportsman 600 twin 4x4 backfiring
  110. hilliard clutch not engaging
  111. 1996 Polaris xplorer 300 won't start
  112. head gaskčt
  113. 1998 Sportsman 500
  114. transmission lube for 99 polaris 400 xplorer
  115. Polaris valve cover blown and fluid leaking from exhaust
  116. 07 sportsman 500 speedo
  117. Please help
  118. Rev limiter problem
  119. Newbee with a dead 2003 Sportsman 500
  120. 2002 325 trail boss not charging
  121. 2006 polaris 500 efi ho
  122. 2000 Sportsman 500 won't start
  123. 2004 500 HO sportsman no spark after wet ride
  124. Please Help! 93 polaris trail boss 350l
  125. Wiring Led lights and lost power to "key on accessory " wire.
  126. Sportsman 800 Twin / gas in the oil
  127. "NEW" 2011 and 2012 available at auction. should we risk it?
  128. Gear selector switch
  129. 2002 Polaris Magnum 325 Oil temp light on
  130. 08 Polaris Sportsman 800 EFI 4WD problems
  131. To much air
  132. 2008 outlaw 525s valves rebuild kit to buy
  133. 1998 scarmbler 400 carb adjustment
  134. 2000 polaris 400 2 stroke 4x4 bottom end
  135. 99 Sportsman 500 - won't start, been sitting 9 years, trying to repair
  136. 96 Polaris 400 Sport hard to turn and won't start
  137. 2003 Magnum 325 need help
  138. 05 sportsman 500 HO Charging Issue
  139. Polaris sport 400 l 2 times of 1999 failure in progress what can it be?
  140. Rear brake reservoir hose 2001 Polaris Sportsman 500
  141. Rebuild Break-in Questions
  142. 2000 Polaris Sportsman 500 4x4, Speedometer not working.
  143. best brake pads 2001 Polaris Sportsman 500
  144. shift linkage 2001 Sportsman 500
  145. Throttle and choke cable lubrication 2001 Polaris Sportsman 500 We are going through
  146. 02 scrambler 500
  147. 2007 Polaris trail boss 330 bogs down
  148. Are there any good LED bulbs or other preferred lighting upgrades for 2001
  149. 99 Polaris scrambler 500
  150. Solenoid clicks but machine wont start (first timer)
  151. 2009 Sportsman 500 restart problem after stall.
  152. Override switch help
  153. How often do the temp switches that run the fan go out?
  154. What is the size and thread pitch of the Phillips head screws that go to the carb
  155. How do I remove and re-install the front plastic on a 2001 Polaris Sportsman 500?
  156. 2003 Magnum 330 4x4 high gear replacement and brakes parts
  157. patching hole in carb housing
  158. what carb can I use for a 96 2 stroke Polaris sportsman 400 4x4
  159. outlaw 525s hotcam stage 1 valve adjustment
  160. Plastic hood help
  161. 90cc Arctic Cat y-12 2 stroke bogs then dies
  162. 2009 Polaris 4X4 700 front yoke stuck
  163. Main Jet Questions sportsman 335
  164. OPT help with AWD
  165. 2004 polaris bumper 2874432
  166. 07 sportsman 500 nothing works
  167. 2001 Magnum 500 Overheating
  168. 2000 Xplorer 400 4 x 4 starters
  169. 2008 Sportsman 400 HO AWD not working
  170. 2004 or 2004.5 sportsman
  171. 2003 polaris sportsman 500 stalled wont start
  172. 2003 Polaris Predator Aftermarket Handle bars and dash??
  173. are there many different clutches for the different models?
  174. attn# retired tech
  175. Polaris RZR
  176. 2005 Sportsman 400
  177. 2001 polaris sportsman 500 no power to switches
  178. Gear select.
  179. 95 polaris magnum 4wd
  180. 08 outlaw 525s big bore kit or cams or carb
  181. 2007 polaris sportsman 800 wont start
  182. outlaw 525s stock hp vs raptor 700r stock hp
  183. 1999 Sportsman 335
  184. Blue 2006 banshee yfz350 still in the crate
  185. 07 sportsman 500 tires
  186. 2000 335 Speedometer trouble
  187. Help !! Polaris predator 500 misfiring after carb rebuild
  188. Help !!Polaris predator misfiring after carb rebuild
  189. 2000 Sportsman 335 tough to shift
  190. 93 polaris 250
  191. 425 xpedition clutch replacment??????
  192. Sportsman 400 parked few year won't start
  193. 1997 polaris 425 magnum 2x4 problems
  194. Replace head & cylinder bolts?
  195. 2004 Magnum shuts off
  196. 2001 sportsman 500
  197. 03 sportsman 700 axle specs
  198. Fuel Valve Sealer?
  199. ITPs wheels lug nut torque
  200. Need New RAD Hoses
  201. 2007 Polaris trail boss 330 mods
  202. 00 sportsman awd light problem
  203. Rims
  204. Overheating issue question
  205. 97 sportsman 500 is this knock normal? Driving me crazy. Help!
  206. 2000 polaris sportsman 500 AWD issues
  207. Will a Sportsman 570 fit in a 5.5 ft Ford 150 bed?
  208. 2004 Sportsman 700 Twin EFI
  209. What is Fair
  210. Trail boss transmission identification/ parts help
  211. 2015 Ranger 570 No response to key
  212. 08 Sportsman 400 ho knocking noise
  213. 07 Polaris Sportsman 500 efi electrical??
  214. 2000 Polaris Sportsman 500
  215. Polaris Sportsman cooling fan tsb
  216. awd not disengaging
  217. SOS MAJOR Fuel leak Polaris Xpress 300 1999
  218. Air Filter - Oil or no oil?
  219. Won't start when warm, instant plug fouling
  220. 97 sportsman 500 compression release spring frustration please help!
  221. Please comment on my camshaft exhaust lobes
  222. Camshaft question - screw missing
  223. Possible Rad leak, but can't find it
  224. late 90's polaris 2 stroke 4x4 no start
  225. Has my muffler gone bad?
  226. Expedition 425 speedometer bypass
  227. Hot and Overheating - need some help ...
  228. 2000 xplor 400 gearcase
  229. 2015 570 Sportsman
  230. 2000 polaris xpedition 425
  231. Polaris Sportsman 335 99 Carb replacement-- throttle disconnect
  232. 86 trail boss 250 r/es starter removal
  233. 2011 Polaris trailblazer 330 won't fire
  234. Carb Question
  235. Polaris Trail Boss 325 2x4 does not start
  236. 2011 sportsman 550 trouble starting in cold
  237. opt
  238. Opt
  239. 2006 Polaris Sportsman 800 - Fan Problem (HELP, PLEASE)
  240. Flywheel fin damage
  241. Sportsman 700 twin engine problems
  242. extra brown wire off ignition coil
  243. Will newer sportsman plastics fit on my 99 sportsman 500
  244. 2004.5 polaris sportsman 500 ho hot/check engine
  245. 4x4 help
  246. 87 polaris 250
  247. '03 Sportsman 700 AWD sounds
  248. Ignition switch failure
  249. 6x6 ranger camshaft
  250. Clutch Puller Thread Size
