View Full Version : CAN-AM (BRP)
- Mod or Trade In?
- problem w/ outlander
- ANY IDEAS?? PLEASE HELP!
- STOCK DS650
- WEBSITES FOR BOMBARDIER
- Squeaky Brakes...."If the shoe fits...."
- NEED Carrier case, Pipe, And lower A-arms???
- Anyone have a frame?
- I been gone a while..... DS is gone.... picking up my 450R on monday...hopefully
- BAJA 2003 sag
- ATV Sport Magazine @ Aledo Nationals
- What size bulb is in the 04 or the 05?
- Any idea about the bomb 450??
- Post ur pics here!!!
- Air filters
- polishing information needed
- DS650BAJA - modification, what's the next step ?
- Aftermarket Equipment
- Parts list to get me going again.
- PAST OR PRESENT OUTLANDER OWNERS: or someone who knows about it
- Starter Solenoid
- price
- EFI how many are running it?
- Gary @TVI injured @ Dunefest
- Purchase advice: Outlander 400 or 330 vs
- texture of ported Intake???
- Why Is My Purge Cloud So Inconsistent?
- Thinking about modifying stock end-cap any suggestions?
- Oil Filter Replacement
- Type and wieght of oil?
- ac pro pegs
- aftermarket air filters
- Oil filter removal???
- New K&N air filter for the Outlander
- Dumont, my ds and Mad Racing Battle on the hill.
- Legal beach or sand dunes closest to new England
- low rpm sputtering
- EFI vs. Lectron
- Drag starts?
- PSI?????PLEASE HELP ME!!!!
- whats in your garage UPDATE
- CAN I RUN 0W 40 AMS OIL IN MY OUTLANDER
- ron wood exhaust gaskets anyone use them?
- Bmw motor?
- need to find LITE tires...but still durable (22's)
- Oil Change just got my DS
- Red River this sunday the Aug. 1st
- where to buy extream haulers?? 9 paddle.
- my pics r up! tell me what u think.
- Your max top speed??
- 2004 ds650 Baja X shocks
- Gapless piston rings
- air pressure-sand tires
- Ride report - front Sand Stars
- dunefest starts tomorrow.
- popping noise
- 2005 X in yellow/ black????????
- And now for the truly bored
- 12 volt aux. power outlet for GPS
- need help ASAP
- Tires
- Its true, HELLO DS.
- Voltage regulator and tail light bulbs
- Do both spark plugs look the same
- Bearings
- Engine Noise
- 04 DS top speed NO ENGINE MODS
- gas
- Its true, bye bye DS650
- In desperate need of left lower a-arm....Help!!!
- DS using lots of oil
- thinking about geting a ds? what should i look for?
- steering help 2003 baja
- TURBO FOR TRAIL RIDING
- lowest octane for 12.5:1 ?
- Another K&N reliability post
- Need some ideas on this DS, Im lossing far to often!
- ds not getting fuel
- oil light wont shut off help!!
- So cal fab
- How many 65HP+ stock bores out there?
- yfz 450 alba pr flow kit
- Aftermarket shocks
- what kind of grease for clutch actuator shaft?
- Aliumin battary box
- Tire question
- Starting problem
- spark plug removal
- oil return line fitting
- Paddletracs...any good?
- Factory vs. Aftermarket
- What happened to the "Whats in your garage" thread that has existed for about two years?
- ATV OIL
- Ds650 Head
- DS Price and speed
- aledo race who's going
- Predator 05 WOW!
- choosing new clutch springs, any recomendations?
- Eaglecollector! When was the Pizmo Date???
- Bombardier Dealers Folding!!!
- Texas sand drags this friday- T&T
- My DS ran me over!
- Pismo 22nd-25th
- clutch is going, where to get....
- Gold Flakes In my Oil!!!!
- any tried smaller ports?
- break in prosses new or old way?
- 14mins and MBRP in ATV MAGAZINE!!!
- 04 baja x...less than 11 hrs...clutch slipping...
- whats this worth
- axle bearings - help
- Had a big accident with the ds :(:(
- USFS run in
- DS650 owners riding spot!!!!
- Oregon Trip Report - Our recent trip
- stage 2 now what next?????
- standard steelers:Awesome or NOT!!!!
- Check Out My New Pics
- Engine Basics, Spark
- Front brake res and lever
- BAD LUCK WITH THE BOMB!
- DS Days 04 just over a month away, lets get planning
- wiring baja tach
- bogs in 2 gear starts!!
- Questions for the Alchoholics
- 22" Kenda Klaws???
- got beat by a STK ds!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Air fuel ratio for the DS
- Finally got DS back together
- 2003 baja mis @ 4200-5500 Need help
- what is this??
- Paducah Nationals
- Baja CDI on a regular DS
- Rim Options for Sand Tires?
- look at this poor guy
- What type of LOCTITE ?
- carb mounted filter
- Bent Rim, Tore Tire - Need Opinions
- need intake boot
- air inlet tubes location.
- hot knife????
- tire changer
- Steering Dampener for 03 DS
- Where to get a Steering Stem
- Rode a Bomb in NYC!!
- Advantage CDI
- Jet4power
- spring noise
- ? about oil change
- hp research
- Where is everybody staying at Paducah this weekend???
- No Haulers in SoCal
- unidilla!
- Carb/Jetting
- Where have the raptors gone?
- Extended A-arms/Brake Lines
- Head Bolts
- Valve Springs/Cams
- Silver Lake - First Time - August 20th & 21st
- Another suspension set up question
- Just ordered it
- speedo
- 6-speed trans??
- 04 DS650 ride review on TV show!!!!
- $2000 what to do???????
- oil tank drain valve
- would like opinion of ds owners
- ds 650 swingarm skid plate
- DS650 Stock Mikuni - Jetting FAQ?
- Are nylocks good enough?
- What trails to ride, Big Bear to Arrowhead?
- Jetting (and other) Questions
- Dyno Results
- Sandfest--Little Sahara 2004
- THE RIGHT SPARK PLUGS?
- neone riding this weekend?
- a arm help
- stk crab on alky????
- Anyone use ANTI-SWAY bars???
- Got the new elka's out for the first ride
- High compression vs. factory shocks????
- Mikuni HSR 42mm
- DS Front drag light type tire & Rim?
- DS vs Pred
- Rally no Reverse
- bombardier orfficial wed site
- question on jetting
- ASR A-arms - are they any good ?
- Funny Race Story
- Just added New Pics on MY PAGE
- Mr. HP Downpipe
- look what's cooking @ TVI
- VORTEX'S ADVERTISED 8900 RPM REV LIMIT YEILDS 7891 RPM
- Back tires for a Rally
- Cleaning Your Machine
- how to test a CDI box
- notchy shifting after oil change
- AHHH! that new ATV smell!
- oem torque settings on handlebar clamp?
- Theft Insurance
- ds650 axle and pipe
- loose tube
- Manual for Outlander 400
- Traxter 500 XL Questions
- Anyone Loose a 03' DS?
- Prices on stock engine parts (crank bearings, gasket set, etc.)???
- Atoka test and tune
- Nitrous pumps
- Who's up for Florence this weekend
- ds 450 ??
- Bluegrass State Drag Racing
- got cover off, need part numbers (also have cam tensioner question)
- 954 big bore kit for the DS!!!!!
- sandman430
- is the ds650 the right quad for me?
- please help with tire decision. (long wearing/good traction 22 dirt tire)
- new 22" Extremes
- Oregon Dunes were Great!!!
- graydon proline
- Is it true
- Don Knetzger
- Weight Savings???
- Best size and model of rear tires??
- rear wheel studs & nuts????
- Oil Tank Weight
- What mods do I need??
- West Michigan Sand Drags August 6th
- What have I done? Clutch won't go back together.
- such a thing as QUIET power?
- alba pipe kit or ron woods
- Has anyone had main bearing problems
- Racing
- Turbo's at the Cinders
- clutch cover is being stubborn... any ideas?
- Bombardier website?
- 2004 Baja DS650
- 730 Rebuild Photo
- Where to order MRHP's end cap?
- Help, my DS pulls to the right.
- when to change valve springs....
- what has beaten you?
- carb ??? air screw
- Who carries a quality 530 O-Ring Chain
- boots?
- need ds fenders
- Gearing review.
- Chain Snapped, did some damage, need advice
- k+n prefilter ?
- how are the Terrain Trak tires?
- K&N vs Foam
