View Full Version : CAN-AM (BRP)
- whos going to LS OK. this weekend?
- Got my hmf pipe today
- custom pistons
- Newbie Questions
- A-arms getting scratched bad! What's the best fix?
- Wow, the DS is Fast!!
- Anyone know where to get the new style AC front bumper?
- St. Anthony's this weekend!!??
- BMW 650f CDI Box
- Upside down DS...what will parts $$
- Might need new oil tank
- whats your weight?
- gas drippin out of carb overflow tube?
- Stock Shock question ????
- Rode friends baha on track this weekend....
- Stripped 2nd Gear?
- Alky question
- 01 stock a-arm
- please help with tow advice
- HOW MUCH DOES A 44mm LECTRON RUN????
- Hello...
- stock comp ratio?
- 13-1 piston
- baja lights
- Aftermarket parts for outlander
- Clutch lever questions
- Question on how to make a ds650 rev QUICK! or quicker I should say...
- Oregon dunes alcohol policy...
- help need rear plastic A.S.A.P!!!
- Heat sensor
- Aftermarket Swingarm
- Removing stock decals !!
- Spark plug color
- 23" tires with fenders?
- Noise
- Looking for juice
- florence for memorial day
- pro circuit pipe help?
- Heading out for Little Sahara @ 11:30......
- Quick, i need help! Wiring a Tach....
- Rabbit Creek Drags in Texas
- The Dunes trip planned (La)
- This $uck$
- 760 carillo rod with titanium needle berrings!
- East coast
- silver lake anyone
- hd clutch springs
- big tires and fenders?
- Repair manual?
- Need info on LS in OK, quick please
- Anyone have a stock swing arm laying around
- OMG Dual exhaust rocks!!!!!!!!
- which full pipe for 03' baja
- TT Racing HELP! Tranny problems!
- Post Problem with your Outlander here.
- Cams too big???
- jetting for elevation
- help, charging system
- Florence this weekend.... anyone interested ??
- WEB cam grind numbers???
- Sputters When I Wheelie
- 720 Dyno #'s
- Coos Bay, OR restrictions
- School me on paddle tires
- Wireing help please help me!!!!!!
- valve adjustment need help
- hmf pipe
- question about transporting the DS, whats the owners manual say?
- AC nerfs?
- cams
- Riding in Arizona
- gary ran his 760 at the drags this weekend
- 12hp....oh yeah!!! 25hp....WEEEEEEHAAAAAAA!!!!
- CHECK OUT CUSTOM DS ON EBAY
- New Member!
- Dual 39mm FCR tuning? (Gas)
- magneto puller
- Samcoe 720 update!
- installed dual exhaust pics
- Hour meter setup.
- ORBA goes to bat to keep Sand Mountain open!
- Outlander + Warn 3.0ci Winch?
- Loud clapping noise.... and can't rev past 2500 rpms..
- Anyone know what a set of Baja Wheels '03 and
- Tires wont come off!!!!
- Well I did it
- Any East Coast bro's out there ?
- ran a kfx with dual exhaust
- tuff quad
- Tire Presure
- Carb Removal
- will supertrapp disks fit alba exhaust?
- finally king shocks in the dunes
- ** Dialing in my 45 **
- if you want a fun project and a fast quad
- Compression Ratios - best way to achieve them??
- How hard is it to tear down?
- LOL, Have you seen the Polls lately???
- Need Help - only a week away from the long weekend
- Coolant question...
- question for those running alcohol?
- Ds 650 oil light
- Can't seem to loosen the axle nut
- ds650/ds650 baja question
- OMW DS650 VS. Stock Dyno Chart
- Little Sahara, Ut this weekend??!!
- Does anyone ever use the chat room??
- RWR Cam's???
- Fresh rebuild difficulties! Need feedback!!
- HSR 45 Jetting Suggestions
- little sahara THIS WEEKEND
- 3 hrs on the Dyno - WOW!
- ATV mag.on tv..anybody watching?
- Silver Lake
- The Trailer Park
- MBRP headpipe question
- Help Quick Please?!!
- message problem
- Twist Throttle for Winter??
- does alba pipe kit require repacking?
- Are trailtech lights worth the 90 bucks??
- fullbore plastic
- Is this a HSR 45??
- Need help with clutch questions.
- OMW DS650 Dyno Chart
- Dual Exhaust Update Read !!!!!!!!!!!
- Nos question.
- guys, help me rock this poll- - DS's rule..read
- Seat Flexing problem.
- a few questions about the 03 Baja and 04's
- Another DAMN Tornado :(
- How wide?
- ATTENTION: Pami 703 Owners!
- Do Dealers Stock Any Parts??????
- Do I have to buy a Tach specifically for a DS, or any will do?
- Anybody have a front sprocket cover? i need one
- Prowd to own an Outlander
- Please Help Re-open Closed Dunes.. Deadline May 23!
- I need help- real lean
- Part Number for Starter O-Ring / oil leak at starter o-ring
- Found a good place to buy lights..
- Where can I get a nice on/off switch for the bars?
- florence this weekend
- Split cases???
- Vortex and sand hill climbs
- Help with air screw
- i bottomed out to the max today.....
- Is the DS any good for GNCC
- Are the stock pilot jets Style vm28/486
- rad axle
- 04 DS650, Baha and Baha X Production Schedule
- I need new clutch plates AGAIN. just need some advice.
- How do u lower the ds650 ??
- Rear shock?? please help.....
- Help...Ball joints
- stock carb question
- 770 raptor or 830 baja
- Front shock bushings?
- timmy boy
- ppl w/ shees or no anyone w/ them
- Environmentalists want to bar vehicles from part of Sand Mountain
- Pics of extended swingarms anyone?
- Got my OMW motor back!!!!
- DS won't wheelie...DS the problem or is it me??
- My exhaust makes a "pop " noise when i turn it off
- Advantages in going back to stock carb??
- aftermarket headpipes
- Need head/cylinder shaving info!
- stock crank????
- Watch out you Mooks!!
- check out this pic, DS in back of big truck!
- Toe settings
- Alba Graphics Kit Installed. PICS INSIDE!
- rev limit
- Need to fix... or need to sell?
- rubber boot gone bad
- putting pics on your page and having the link?
- ralley reveiws
- New purchase, need some help
- Played hooky from work today... went to the dunes:)
- 24hr le fud bike
- I'm disturbed...
- Cinders; Memorial Weekend
- Question for MBRP (or anyone else that would know)
- weight changes
- I Just called Motion Pro
- A-arms
- The old sand tire debate-- about fronts
- Jets?
- DS650 gas mileage
- ole yellow went 7.9's in the 1/8
- Need help with brake fluid
- Jetting Question Lean or Rich
- How much lighting can I run?
- New Bomb - maybe some hope yet
- What carb does pami use?
- TM 45 Sticking In WOT or AT IDLE!!!!!
- Those darn Tank bolts!!!
- Who's going to Sand Mountain for Memorial Weekend?
- nerf bars?
- Octane levels?
- is the clutch basket right or left hand thred?
- St. A's and Wyoming this Summer!
- Dial a jet review installed, Review.. a real long read
- Please help ASAP!!!!!!
- Busted my seat!
- look what i did
- toothed thing in center of clutch?
- Dumont in the morning!
- She's gone.....
- Jeffnrivercity's DS
- Bad wreck, need some parts. :o(
- Gas or alky??
- Stock Intake ??
- Seems like there are tons of differences between years...
- All you Missourians.....(and those close by it:D)
- TM48 Settings
- Texas Sand Drags
- Generator limits on the DS?
- Anyone ever ride at LA Dunes
- Need sprocket cover
- Gorman Or Dove Springs this weekend!!
- New Elkas!!!
- antifade brake hub
- BSR 42mm Carb
- 10 Hour service.....
- Finally got our new Weekend Warrior home!!! (PICS)
- i need more clutch help... please!
- Wher are you going?
- Stock swingarm
- VForce or DS? Help!!
- BigWaynester's 760.....
- Outlander 500/650?
- Now my choke cable won't budge....grrrrr.
- subscribing to threads
- Billet aluminum bumpers or how to add 40 lbs to a DS
- How would shedding 5 lbs. of internal mass SOUND!!??
- One Of the Most Informative Thread I've Read on Jetting
- Tough paddle?
- new to this site, thinking bout getting a ds
- WELL AZ GUY"S
- k&n vs uni-any opinions?
- Hey ThePunisher
- Piston & cams?
- Jetting for VA
- ds650...what gas do you use?
- armidillo a arms
- swing arm
- will this Oil filter fit?
- where to camp at florence
