View Full Version : Polaris
- Stripped Oil Drain Bolt
- Hey old polaris tech
- Polaris 300 4X4 - W948130 oil level
- XP with BigHorns
- Wheels wont turn when i hold down the gas, it just make a clicking and grinding sound
- Scrambler 90 prob, need help
- 2006 sportsman 800efi
- 2004 ranger 4x4
- popo500 misfireing?
- polaris ranger vavle cleance
- Sportsman AWD Question
- Playing in the mud on the 850...
- Polaris scrambler 400
- 07 800 x2
- Starting problems polaris 300 trail boss
- upgrade polaris cyclone
- 2003 Predator 500 Oil Hose Question
- Polaris Trail Blazer 250 Oil Injection
- rev limeter in speedometer?
- '96 Explorer 300 Front Rack Bolts. . .
- rotopax fuel cans
- How much fluid in front gear case
- will this work
- For anyone thinking of installing HD front springs
- OEM Polaris parts
- 1994 Polaris 300 4X4
- xp spark plug
- will a 400 2wd tranny work on a 425 4x4 for reverse gear only to fix or repair the 4x4 reverse
- test ride a success!!!
- Lock N Ride Issues
- Do you think the 800 is too big for my daughter
- High rev it order to move it(2003 SP500 H.O. 785miles)Is this Normal?)
- XP not trail legal?
- 2004 polaris atp belt part number
- 600 Sportsman coolant leak
- over charging sp 500
- Bobcat, Polaris announce alliance
- carb for winter
- NEW GUY
- Front Diff. Fluid '05 Sortsman 700
- XP build date location
- Anti Roll Bar
- Rear Cargo boxes/ seat
- backfire?
- Child Harnes for atv riding
- Polaris Sportsman 500
- swamplite for xp850
- Looking at a new ATV you might want to know this..
- Polaris lock & ride windshield
- Buying a new machine, can't choose which one, need advise
- '06 Sportsman 500 EFI Fuel Level Help
- 2001 325 explorer
- 99 Xplorer 400 Rear Axle
- double trouble sport 400
- XP Turn signals?
- pull start only
- 2000 400 Scrambler chain tighten issue
- 2008 800 HO Tranny Issues
- 2000 250 Trail Blazer vin location
- steering help on sportsman
- just bought a left over 2005 predator 500, what kind of mods...
- WHAT KIND OF SHOP RATES ARE YOU FINDING?
- I can't find a slip on for my 2008 800 Touring...
- 2005 sportsman 500 clutch noise
- Icon Issues
- What would you suggest?
- SP500 Waterpump Seal Help
- Changing front springs
- 400ho speedo problem
- what oil for the front diff on a 06 800
- spring installation
- Trailering in Park
- 2008 500 EFI-Fan??
- Newbie
- Softer ride? Sportsman 800 or 850Xp
- Rotopax tank mount options
- Dumb question - how to recoil winch cable neatly
- need oils other than polaris brand for polaris hawkeye 300
- Is there anywhere to buy fluids online?
- Valve adjustment
- 05 trailboss 330 stater
- CIRCUIT BREAKER FAN
- electrical problem
- pirmary clutch wear
- Trailblazer with a noisy rear end
- Question
- What does everyone think about using Royal Purple?
- wheels not spinning so freely
- 1993 sportsman 4x4 350 Awd help
- Polaris Industries Inc., Bobcat Company Announce Long-Term Strategic Alliance
- 1993 sportsman not charging HELP
- Xp don't like to start in cold weather (update)
- Who else has a 1987 polaris cyclone?
- New '98 500 Sportsman Owner
- Help, 91 trail boss 350L
- Letting POPO XP run all day!
- procom rev box?
- coolant
- XP Wheels Dont Fit.
- One Bad Mother...
- 92 trailboss front a arm bushings
- stock tires
- Polaris HD srpings
- 92 trailboss dies off at top end
- add ons and warranty issues
- 05 predator 90 how to adjust the idle??
- Quadovator 3 light conversion
- 2006 sportsman 800efi coil test
- Axle Upgrade
- winch mounting double tube bumper
- wheel sizes
- anyone runnin outlaw mst's?
- aftermarket springs vs. polaris hd
- What jets ??
- Mud Bugs
- 02 polaris sportsman
- sportsman 500 cam check and replacment
- Problems with a '00-'01 Polaris ATV (Scrambler 90cc)
- Outlaw 525 Front A-Arms
- poPo 700-800twins starter drive bushings BEWARE
- 97 xplorer 500 no power form mid range on?
- sport 400 counter balance fluid
- scrambler 500
- Fender flares and mud flaps
- The Mobil 1 oil filter for the Sportsman 2008 800cc is...
- 07 Sportsman 800, EBS or non EBS?
- Frayed winch cable
- Sportsman wont start
- place to order parts
- 1992 350L SPARK PROBLEM?
- 04 Sportsman 700 Bogging
- 4x4 kicks on when button is off?
- what coolant should i use?
- Fix a pin hole leak in a polaris ATV tire.
- Download 1997 Polaris trail Boss 250 manual
- Looking to buy a new trailer (Anyone owned an H&H trailer)
- Hi all, i just bought a 2000 Xpedition 425
- Shocks / struts rebuildable?
- 850 XP are they really all that?
- Polaris circuit breaker problem...
- X2 seat
- clutch questions?
- Nuclear Sunset color code
- polaris only run an hour or two then has to cool or it wont run
- 06 polaris hawkeye 300 2x4/AWD maintenance HELP!
- 500 Sportsman 04.5 clutch adjustment?
- Dealer Wrong.....?
- BEST EXHAUST
- 1996 300 explorer
- 1998 Polaris scrambler 400 4x4 front shocks?
- 1999 sportsman 500 tires
- New Isuues with the XP
- 1999 sportsman 500 question
- headlight aftermarket
- cv boot clamp
- 1998 sportsman 500
- Babbitts poor service
- 97 sportrman 400 4x4 2stroke Oil/coolant problems NEED HELP
- 08 400HO spark plug
- my sportsman can fly
- 2006 polaris sportsman 800
- Trail Blazer Chain
- HELP! 1997 Polaris Trail Boss 250 engine oil or Transmission oil
- Sportsman 500, no electric start, lights and instrument panel flicker at higher rpms
- Piston help on Xplorer 400
- Xpedition overheat lamp
- need new drive clutch 700 efi
- replacing winch line, HOW?!
- HAVIN A BABY TODAY!!!
- 2009 xp 850 spring preload adjustment
- 1999 polaris 250 trailblazer dirt fly wheel housing
- FMF V/S Dynatek controllers, and what mufflers fit my 800?
- EPI drive belts any good?
- Which mod is the most bang for your $ on the scrambler 400
- Stablizer Bushing
- 07 sportsman 500 H.O.
- 94 4x4 400L AWD problem in H
- XP Brake pads after 300 miles
- reverse lock mod
- powering fan with acc plug
- Who ships OEM parts the fastest?
- Please help all polaris techs out there
- question
- Sportsman 800 HP
- U-Joints for a 01 sportsman
- How do you know when a rear shock needs replaced or rebuilt
- 2-50 oil what the h**l Polaris...
- Polaris PLow won't fit Hawkeye-Help
- OLD POLARIS TECH
- Vision 161 Bruiser Wheel
- newbie
- Sure Power Failures
- How do I check the oil?
- IS IT MY STARTER?
- 1999 Sportsman 500
- New question bout cluth and belt housing?
- Fender Flares for a X2
- EPI or HIGHLIFTER
- Plastic for 2001 scrammy 500 ho
- adjusting rear shock on 2001 Polaris Scrambler 500 2x4
- Weak front springs on 06 800 (RED)
- AAEN pipe for 800
- 400 Xplorer front chain help
- looking for a service manual sportsman 500 !
- sportsman 500 awd.help!!!
- Front wheel locks in drive when only in two wheel mode
- 27" tires on 2008 SP800 stock rims
- Sportsman 800 vs. 800 touring what's more comfortable for one rider w/a bad back?
- thermostat
- Sportsman 700 coolant leak
- Carb air screw
- Recommended oil
- Used parts
- 1998 Polaris scrambler 400 4x4 water pump? Help
- anyone else have a discolored muffler on a 800
- 2005 Sportsman 500 - electrical problem
- Cooling fan motor
- rotopax or Kolpin gas can
- What winch
- Smoke Out of Exhaust
- EZ-Lift
- 1999 Scrambler 500 HO
- 2007 Sportsman 500s
- Ever try to paint your plastic?
- 08 SP 700 accesory plug +/- wires
- How do I find out the re-sale value?
- 2002 xpedition 325
- 2000 sportsman 500 rev limt or switch
- 1500-2000
- 07 800 X2 will not start
- sportsman 500 w/ 800 exhaust, is this ok?
- sportsman 500 shifter
- 97 sportsman 400 2 stroke oil in coolant?? HELP!
- Serial number question???
- predator
- Highlifter Springs
- Urgently Needed
- Ground strap on motor?
- KIDS quads motorcycles NOW ILLEGAL FEDERAL LAW
- breaking through the ice
- Help all you techs out there.
- Tires
- 02 700 Twin
- Oil in recoil starter
- New to forum and chain question
- 850 torque specs needed
- First ride on the 850XP.
- New to the forum and this is my first Polaris.
