View Full Version : Polaris
- 1996 Polaris Trail Boss Carb Issues
- Sportsman 600 Performance Upgrades
- xplorer starting problems (2 stroke)
- carb over flow leaking gas
- Rattle from front end on SP800
- 2005 verses 2008 sportsman800
- Need Help with 1995 425 Magnum
- trailblazer tranny fluid
- clicking in reverse
- 03 sportsman carb issues
- Anyone have an 2007 450 please help. (Or experience with one.)
- AWD light
- Brushguards
- 04 Polaris Sportsman 500 HO Head Gasket
- Sportsman 600 - Considering Purchasing?
- New Sportsmanx 850 XP Color for 2009
- outlaw 90 airbox improvement?
- Finally Clean
- 300 mile atv ride on the north soo line atv trail. who wants to go with in june 6th?
- Sportsman 700 Starter issues??
- 05 sportsman 500 EFI Issue
- Front differential compatability thru years
- front diff
- Sportsman Xp paint
- scrambler front cv joint cleaning
- Sportsman trade ups on the XP's
- 98 SP 500 rear axle u-joints
- trail boss engine swaps
- need some spec's
- Front Cv shaft removal
- 1996 Polaris Trail Boss 250 rich idle
- scrambler questions...
- Polaris 500 H.O. First Service
- sportsman XP skid plates / rock sliders / cv boot covers
- Should full choke = increase in RPM's on a cold start?
- whats the best way to carry more weight?? shock replacement with ranger, or 2x ?
- 2010 rumor
- regular gas versus premium gas fuel for your atv
- What is my Quad doing??????????
- 800 tranny creeping
- 500 is hot
- Aftermarket oil filter for the 850 XP
- CV boots - outboard or inboard
- scrambler 90 belt removal
- wisconsin riders
- Thoughts on a trade
- Help #2 (starter now)
- starter voltage and clutch align
- Double Tube Winch bumper instructions
- K&N Filter
- Help with the predator (camber)
- rear diff still leaks 06 700efi
- 500 Sportsman- ready to change fuel pump?
- Carb question, correct jets.
- 05 MV7 Hot Light
- 2005 Sportsman Tach Problem
- 1986 250 Trail Boss won't Idle
- 03 sportsman 500 oil leak
- 1999 400 coolant leak, need advice
- Sway Bar Bushings
- 07 Sportsman 700 Back firing
- 250 2 atroke won't start
- Trailer for my x2
- trailboss 325 won`t start
- Well I broke the front diff Again....
- broken front cv joint? hey,OPT I NEED YOU
- VIDEO-PIC editing software (WINDOWS)
- Brake lights don't work...
- bad rear wheel bearing on 02 scrambler
- 06 800 using alot of oil???????
- removing needle seat
- 03 Trail Boss Magnetic Switch
- Problem with 400 Xplorer
- 1994 400l master cylinder piston removal
- XP's a DEEPER look inside
- Installed new style clutches on 03-700
- 850 With 30" zilla's
- 850xp Tires?
- 500 ATP swingarm R&R
- Transmision oil?
- Newbie with an oldie and some questions
- Need a front housing differential
- Skid plates
- Roller secondary vs. Stock
- Camelbak
- where can i get a rear gas tank for my sportsman?
- timing on 04 predator
- 1999 Polaris scrambler 4x4 500 coolant leak?
- Sportsman 500 HO cam
- 80's trailblazer 250r/es tranny question
- how to break in a new belt
- 2004 speedometer question?
- 02 Sportsman Suspension
- New to me 500 ho. Oil change info
- Winches
- rims/tires for sale
- 2000-2001 sportsman any problems?
- 850xp tire out of round, normal?
- Need help finding a part for 2002 Polaris Magnum 325
- New Tire Report-ITP Terracross
- XP850 Broken A Arm update
- Plow Lights Sportsman 800
- Where is my gas gauge 2002 Polaris Sportsman 700
- will they fit
- trail boss charging issue...ideas???
- Sportsman lights surging
- xp with bighorns?
- Polaris ATV question?
- XP belt....good news....bad news
- Rear cargo boxes
- EPI clutch springs
- torn outer cv boot
- 1995 xplorer 400 has low gear only..help
- front hub bearing torque
- 2005 sportsman 700 efi problem!
- polaris sportsman or artic cat????
- 2005 Sportsman 800 engine noise
- 2004 Polaris sportsman Axle trouble
- 02 Sportman 500 Stalls when fan kicks on
- Removing axle
- tuning adjustment on a 02 325 magnum
- 25" tires on a Hawkeye
- Looking for a service manual
- (2) Scrambler Questions.....
- broke my front axles
- 06 Sportsman 500 WOnt start?
- 2005 EFI 500 Sportsman
- XP abuse
- 08 800 high idle
- 06 800 vs 08 800 belt
- scrambler cough
- 800 using oil?
- 06 800 sp exhaust hitting motor
- 2010 Line ups?
- Possible ECM problems and recall
- Hawkeye rear suspension creaking
- 72" plow on 850
- any probs. with 07 sportsman 800
- 700 efi hitting on one cylinder
- 2006 Sportsman 450 stator problem
- '09 Polaris 550 XP or '09 Grizzly 700 FI Auto
- 500 sportsman low beam light?
- 04.5 SP 500 HO plastic oil tank/plug
- new winch
- wrecked..
- Engine smokes blue smoke sometimes
- Polaris trailboss 350l carb issue?
- rims for a big boss help
- scramber pipe
- Its a 2006, its blue with racks and its a 250cc....I'm just not sure what....???
- Couple of jokes to keep ya'll cracking a smile!!
- Rear CV boot on a Sportsman 600
- Help 2005 sportsman stalls after 20 min
- scrambler no spark
- 1996 Magnum 425 bogging and puttering
- Polaris CV Joint
- NEW XP's
- Tow or truck bed
- Choke pull stuck
- Posted some pics of a few mods on 07SP800
- 06 Outlaw 500
- Fuel
- 98 sportsman 500
- Axle removal?
- Winch cable question while plowing
- Hawkeye clutch noise..
- outlaw 525 problems
- xp fuel tank
- trailboss 330 parted? get parts?
- 2003 Predator Modification question
- Where to solenoid on 850xp
- help finding snow plow for trailblazer 06
- xplorer 400l throttle cable
- Bigger Tire questions (again) - Maxxis Bighorns, and original vs. 2.0
- New Helmet
- 01 Magnum 325 Help
- Scrambler front gear case oil change - ned help....
- polaris not running right
- 88 polaris 250 4x
- New Bike buyer
- 2008 trailblazer thinks its hot
- 850XP Service Manual...
- Polaris Hawkeye
- scrambler supesion
- 04 polaris 90
- Will Bighorns fit an 850?
- Rear drop rack vs. bolt on cargo box
- scrambler wont start
- what drive belt to use?
- scrambler 90 piston gap
- polaris 90cc 2 stroke problems
- polaris 50cc head torque settings
- ATV cover problems
- Scrambler rear axle help please
- 97 xplorer 500 ball joint
- Sportsman 700 timing
- Air Filter
- Rear Lock and Ride Cargo box dimensions
- Bypass reverse over ride switch?
- 2007 800 Sportsman Pull Rope
- 500 stator
- 2006 Polaris Sportsman 500 EFHO
- Explorer 400 problem areas?
- Polaris 500 stuck in low gear
- recoil starter.... hee hee
- 400 HO Lights
- Trail Boss Recoil Spring
- Need help with 03 predator 500
- Exhaust and Computer upgrade
- 94 400L Stator Replacment Question
- ATV tools
- Cracked A Arm
- Kill Switch Trouble today!!
- 2009 sportsman 500 ho and water
- 800 h.o.
- Newbie Help please
- clutch kit
- 88 trail boss 250 no spark, confused!
- Need help with handle bars locking
- 4wheel problem
- Idle problem with 500 EFI 2x only when hot???
- Ricochet or aluminum products a arm guards
- 2007 X2 Will not Ilde
- Attn. gmcstepside + pedals (did you fix your overheating?
- 850XP survey, hours, miles, riding style, terrain type, belt status
- Help! No electrical... everything went dead on my 2000 Sportsman...
- 2000 Polaris Scrambler 400 4X4 CV Boot
- 04 Scrambler 500 Carb
- Ricochet Aluminum A-Arm Skids For XP??
- radiator trouble
- Tie Rod ends
- 2003 polaris 400 cvt help
- 96 Sportsman 500 Rear CV swap
- shocks for 2001 scrammy 500ho
- Need Silencer for 2001 400 Scrambler
- 01 xplorer cdi box problem
- scrambler 500 pipe (where) need umph. input
- Good advertisement for Polaris at Walmart
- Car fan in a sportsman?
- EFI Sportsman Runs than quits
- Outlaw 500 mods
- 2000 Scrambler 500 4x4 not engaging?
- 2000 polaris scrambler 500 ???
- 500 sportsman. Whats wrong with it?
- qustions on 2001 sportsman 500
- Oil filter question
- 2008 Sportsman 400 lift?
- 2007 Sportsman 700 Spring Issues
- sp 800 creeping forward at idle??
