View Full Version : Polaris
- You guy"s using 0w40 mobile 1 in your sportsmans,what do you think about it?
- HELP! 500 EFI won't fit in p.u. bed.............
- water pump seal
- Painting Shocks
- 96 magnum 500
- Rev limiter
- would a preditor be a good idea to buy
- phoenix shocks
- ordering new tires
- Oil drain plug leak in '03 Scrambler
- Sportsman 800 E.F.I. break in period
- predator talk
- NEED HELP PLEASE!!!!!
- Sportsman bigger tires
- SErviced my 800 gear boxes today
- sportsman 500 weight
- AGL Question
- brought home the 450
- over night trips
- New Graphics Kit
- sick and tired of hard shifting
- Will Polaris answer BRP's new Sport 4x4??
- Polaris 400
- 06 800 EFI LE Updated!
- fuel filter 04 700 efi sportsman?
- Help...Outlander 800 or Polaris 800...
- Looking To Purchase 500 or 700 EFI
- epi vs. heelklicker clutch kit
- sportsman 450
- First oil change on the 500 H.O. ---A walk thru...
- trail blazer reverse broken ? help
- X2 first real ride
- just bought 06 500 h.o
- Heelclicker White Spring
- The only way to fix the rear foot break on a polaris!!!!
- Moose Bumpers
- sportsman 800
- Polaris MV any feedback
- Phoenix AZ guys I am a moron..
- Aftermarket Exhaust ??
- How can you set the idling on a EFI
- Oil in Xplorer400 starter
- Scrammy 500 Towing/Low Speed Question
- Price varies greatly among dealers for 800 EFI...Why?
- Scrammy 500 drive belt
- pure polaris pipe and jetting?
- Maintenance Manual for 96 polaris 400 Help!!!
- High end rev limiter 250 trailboss
- Hole in wheel
- 500 HO/EFI Gas Mileage
- mobile one vs Polaris brand
- Question reguarding AAEN jetkits on their pipes
- My new AAEN pipe for my sp800 is on the way!
- Top speed of 800 E.F.I
- Scramber 400 seizing - pipe too restrictive?
- Sportsman 600/700 Camshaft test results.
- ATV Source puts Polaris 800 over Bombardier 800
- 800 E.F.I. and fuel economy
- Just Installed new half shaft
- Bear Claws or Dirt Tamers
- need help starting my 88 trailboss
- reed conversion
- 500 scrambler clutching
- Seriously looking at 800 E.F.I.
- REFER-A-FRIEND Coupon?
- '05 Scrambler clutch springs - confused
- Svc Manual - Shock / Strut assembly
- FREE POLARIS STUFF!
- 600 SP still bogging
- Amsoil motor oil?
- Rath Ceramic header ride review and jetting info...
- trailboss carb problem
- cv boot protection suggestions!!
- Best years for a used 500HO
- What happened to Fisher's ATV World??
- 2 scrambler questions
- Winch and brushguard install
- Oil Leak from Valve Cover - '04.5 700 EFI
- Cooler Rack For Scrambler
- hows the new outlaw?
- Starter Spinning Backwords
- rear suspension support
- 04 Sptmn 500 OH shutting-off
- one way valve?
- Secondary Spring Chart
- sp 700 leaking fuel?
- 06 Sporstman 500 LE Oil Reservoir Location
- Sportsman 400 primary spring
- Sportsman Timing & Float questions
- Base gasket check?
- 2000 Scrambler hit water and quit
- Need help.Asking price
- Predator vs Outlaw
- used price on a polaris....
- Magnum 425 cooling fan woes
- aaen stage 4 worth the $$$ scrambler 500
- Pedtator rear hubs?
- secondary setting
- Hawkeye IRS
- 2006 Scrambler 500 Fuel Range
- Hawkeye Sputtering
- Monkeybutt 1 week away
- Clutch died !!! NEED HELP
- clicking sound
- ATV Drag racing
- 05 sportsman battery dies while sitting
- Fuel Range
- Sportsman X2 Vibrator.
- PWK & HO Ignition jetting for Race 400
- 500 HO, rear end noise
- scrambler serious electrical issue
- AAEN Top end pipe silencer question
- it wont kick over
- 2004 700 EFI problems
- Sportsman450 or 500HO?
- 02 scrambler X 400 4x4 want to put low range tranny from xplorer in.
- 00 scrambler 400 4x4,would like to sell whats it worth?
- valve adjustment on sp700
- installed gorilla winch
- mudlite xl's
- free winch offer
- Had valves adjusted on SP500, but can still hear valves chattering Help!
- Have You or Are You Purchasing a new ATV between March 23 & June 21 of 2006?
- trailboss wont move
- Sportsman 700 Tires. . . .
- Hawkeye high altitude tuning
- Rattle noise in my Scrambler
- AAEN Top End pipe concerns and questions
- i need a shock now!!
- how to keep riders off of my property
- Interested in new Scrambler
- Clutch Setup 06 500EFI
- Mud Run in central WIsconsin
- Exhaust question
- I finally bought my X2!!!
- CPI pipe clearance?
- What first attracted you to Polaris ?
- rear hub removal onmy sportsman
- Slower times?need help
- Qicker Backshift?
- 700belt on scrambler 400, how to shim?
- Help on Winch install...
- 04 sportsman 700 efi blink codes
- Which Predator cam to buy??
- Clutching 101?????
- weight of a 97 400 sport
- 06 Sportsman LE ?
- lift kit for polaris X2
- What size jets?
- JB weld Strength?
- Misfireing BAD
- clutching basics
- What is largest tires you can mount on 400 scrambler
- Sportsman 800 Sporty at all?
- Play in the back wheels of my 06 500EFI
- 800 creeps and inconsistant idle
- Time for new wheels
- trailboss idle and backfire problems
- A nice Mag test of the Outlaw
- What stuff is in a clutch kit???
- Piston question?
- more on the dry tank
- Vision Wheels....
- 95 Xplorer 400 AWD - Carb Problems??
- Put on Pipe and clutch kit, slower!?!?!?
- DYNOJET
- 95 Sprtsman 400 4wd button
- Any Thoughts on This ? Anyone
- 05 Predator brakes and air filter
- Must have items for the rear storage bag
- winch plate
- 2004 Sportsman 4x4 front cv joint HELP!!
- Razr2's on Scrambler?
- 05' models for AAEN?
- SNAPPED LIKE A TWIG
- Sport 400 vs. Scrambler 500
- 03 sportsman 700 oil pressure problems
- Should I buy a Trail Blazer 250
- predator trouble
- K&N
- ftwflh tells it right
- My Predator wont idle before it warms up
- 1995 scrambler 400 decals (aftermarket)??
- Has anyone changed axle bearings on Tb 250?
- Head gasket on 400 Sport
- 2006 Sportsman 500 brush guard
- Scrambler Reliability
- Sportsman Electric Fan
- 400 engine problem, crank bearing part #'s
- plow on a scrambler
- 2004 polaris sportsman 500 starter solenoid
- Starting Trouble
- 06 500EFI fuel leaking in headlight pod
- Sportsman 400 4X4 problem help!!!
- my new sp800 beat by a BRP 650...... UGGGG.....
- Ran my sportsman dry
- Help-250 Boss Crooked wheel?
- Wussed out on the SP 700...
- My Scrammy Clutch
- Smelly 06 500EFI LE
- starter noise in 2005 500 sportsman
- Front Axel play
- Bad Sounds, Popping
- 1999 scrambler 400 coolant leak???
- Quick Question
- clutch question
- Sp 400 driven clutch ?
- Scrambler 500 any problems??
- whats better?
- Oil in side cover
- She's loose
- Zero preload Scrambler suspension
- NGK Iridium Plugs
- ITP TIRES
- Polaris Sportsman 90, kick start shaft sheared
- Polaris Cyclone Transmission
- Piston and valves hitting!!!
- Need advice on reinstall of front half shaft (circlip problems)
- No 4x4
- Gator Tire Size?
- 500 HO IDLE IS LOW AND SPLUTTERING
- scrambler 628 kit
- Done With ATV's... For a Long Time Anyways
- Outlaw??
- 98 Sp 500 Cam change
- NGK Plug Trial
- 05 400EX, 04 pred, or 03 660r
- Counterbalance shaft for '97 400 Scrambler?
- 98 400 sport,Pop goes the piston!!!
- Handguards For Scrambler
- Questions on the POlaris Phoenix
- 2002 500HO Won't Idle
- bad idle
- explor down! upgrades?
- clutch problems
- Whats the difference?
- belt play
- Sportsman 700 bolt pattern
- I am trying to decide on some wheels and tires
- 4x4 NOT!!!
- Primary setup
- 800 Sportsman rattling
- SCRAMMY 500 VS NEW BIG BORE SPORT UTES??
- ATV Rachet Winch
- Backfiring sportsman 700
- 800 oem duals on 700 ?
- blinking lights/pod curcuit breaker replaced!
- 2001 scrambler 500 4x4. wont start, need some ideas. probably electrical
- winch mount
