View Full Version : Polaris
- HPD airbox mod for 500
- swing arm problems with polairs trailboss 325
- anybody still waiting for hpd?
- water in oil
- Price Question
- puttin a snowmobile moter on the trailblazer...
- cyclone problems
- Little Sahara,Oklahoma Memorial Weekend
- Who knows Magnum 4x4?
- Trailblazer 250 problems
- installed aaen 38mm and clutch kit in 700sp
- Sportsman 700 = 7.96 MPG
- CMF Cooler?
- Electrical I Think!!!!!!
- The Beast's speed
- 628cc Scrambler
- 400 power?
- HUB FLUID
- Scrambler oil change
- sp 700 clutch upgrade ?
- 96 500sp - replace rear u-joints, still have wobble in steering??
- wix gold part# for SPHO
- Totaled Sportsman
- Clutch buttons?
- Where to buy chain lube?
- Reverse Rev Limiter
- SC 90 Just won't run.........
- MR1 fuel picks up the HP
- Remove the mud flaps, plug the holes
- Just updated my weight savings doc
- Pipe & Jetkit for my sportsman????
- Trail Blazer pictures
- hpd 500 airbox and carb mod instructions
- Pics of scrambler and sport????
- Battery Removal
- Scrambler 4WD having problems/wheel is loose and leaking!
- Gas leak on 2000 325 Mag
- Service Manual for 97 Scrambler 400 4x4
- SP500 with intermittent 'stuck in gear' problem..............
- Thanks Brent87lt1
- the polaris that just won't spark (I really need help with this)
- buttons;driven or drive clutch?
- 500 h.o. creeping /killing
- HELP
- 00 polaris will not start
- weight
- 2000 expidition 425
- Rick Ritter's stage 1 kit works!
- sp700 winch mounting plates
- Scrambler transmission
- http://www.arches.uga.edu/~peteuga/Tech_Infox.html
- sp500 grease zerks
- RcR
- Cheap price for D.I.D chains?
- scram idle adjust?..please help
- Questions about Polaris Trail Boss 325
- Sportsman 400 or Kodiak
- Any Polaris Mechanics out there??
- Gator Tires
- Gilbert,MN Offroad Park
- Extreme
- Too much water for SP90
- 97 scrambler 400 4x4 - lost reverse - HELP
- 99 SP500 vs.02 SP 500 HO steering
- Anyone have 98 Xplorer pics and info
- You won't belive this
- nerfs
- 99 Sportsman 500
- SP700 Clutch Kits
- Chain length?
- Hubs locking in in reverse AWD, Help!!
- How do you....?
- HELP!
- WOW! $5.50 a gallon for 108 race gas, I got
- Wrecked the 400 Sport today
- clanking sound from the front of sp700
- Anyone have a gray clutch cover?
- 700 Air Box Stuff
- 425 has a miss
- What the heck is wrong with my Xplorer?
- scambler creeps in gear
- remember that 205 psi on the trailblazer.....
- Need torque specs for Scrambler 500 4x4 front hub
- 500 scram troubles
- Sportsman 500 front diff. teardown
- SP 700 Mod exhaust OhWhere- OhWhere??????
- Putting the double A arm suspension on the scrambler soon
- How many miles you guys got on your wheelrs?
- Anyone use the LRD Silencer on ther 400??
- 1999 Trail Blazer 250 has no speed, will not get above about 35 mph,bogging when throttle pressed all the way
- Squeek Squeek Squeek
- I Sold My Scrambler!!!
- Removing the ball joint out of a strut????
- the best???
- 2002 Polaris trailblazer service manual
- If you need info on Utah ridding
- Piping a '95 Xplorer
- What is the correct ngk stock spark plug for a 99 250 Trail blazer 250?
- anyone use 38mm carb on sp or scram 500 ???
- looking for oregon guy who bought polaris mods from montana guy a couple years back
- RSE Camo peeling off
- Why buy American
- chain on 2002 Trailblazer
- cheap K&N or Uni amsoil
- mixing fuel?
- K&N Air filter for SP700
- Gearbox
- Scrambler 500 4x4 transmission?
- Scrambler 500 4x4 Noise
- chain break
- piston or carb?
- any body try different sprocket sizes?
- bike's ??
- 2000 Magnum 500 squeaking
- 00' Expidition 425
- EBS not working on SP700
- Polaris at it again, I am selling it this time...
- Reeds = performance?
- 93 sportman 400L FWD question
- Getting HPD Agg. clutch kit.....what about the belt?
- 205 psi compression on a Trailblazer!
- Wait?!?!?!?!??! is there....
- To all with SP700 leaking water pump covers
- doing 70 at low prices!
- H.O. vs. non-H.O. Horsepower
- Sportsman 90 question
- 1996 sportsman any good?
- sport 400L problems
- Wrecked the Sportsman
- Prices
- Pop rivets removal?
- scrambler/sport, chain drive/beltdrive
- wheel noise
- whats faster?
- anybody know a lot about the 01 sp500??
- Which mount for Ramsey 2500 for Sp700
- Shift out problem...any help appreciated!
- what is the top speed on these 3????
- Had an accident,,need advise..
- G-Tech Performance Meter
- Exhaust Gas Blow By
- 1996 Sportsman 500
- Clutching?..EPI vsHPD
- Lincoln hills trails
- Latest word on the best stem bushing and tie rod ends for '00 SP 500?
- Mod Quad
- HOW IS HATFIELD &McCOY?
- AZ400L has left the building...
- huss powa, expedition 425
- sp500 wont go into gear, neutral , reverse lights dont come on either
- Seating tire beads....
- New and need help
- Heel Clickers offered for Polaris ATV's
- 2002 500 HO
- Noise from engine 500 Sportsman
- Scrambler?
- pics of scrambler 500's in action?
- how long for a new sp700
- What's Faster
- Winch Problem
- 400 or 500 Scrammy
- drive clutch wear
- Bump the air pressure to 8#s??
- First year for H.O. motor?
- Just bought a 00 Sportsman 500(lots of ??)
- sp 700 diving problem
- hpd pipe for 500 scrambler
- side swindler
- Polaristar vehicle insurance???
- FTR pipe/clutching
- Ideas on how to prevent quad theft
- Clicking Noise from Sportsman...
- 6x6 ATV
- brake fade on my sp700
- Needle clips?
- 27 inch tri/bi or gators for 700 SP
- best place to buy moose shock covers for SP700
- I'm looking for a....
- 700 Clutch Spring
- Any new info on the New Polaris Sport Quad?
- Rec unlimited is HORRIBLE
- The new 500 cc sport quad is gettiong close
- ?D&D Performance pipe for scrambler 90?
- Lifted my Xplorer 400 up High
- Sportsman 500 CV Boot Replacement
- Anyone know of a good aluminum cleaner/polish?
- HELP!- Outlaws w/w-o spacers on front of 700?
- Sportsman 500 HO won't stay running?
- 700 walks all over 660
- i could only be so lucky
- Sand Drags
- 425 Magnum belt cover
- got head?
- SP700 Endurance Test
- No Spark on Sportsman 500
- polaris online microfiche?
- trailblazer jetting problems
- My front drive shaft turns all the time.
- Sportsman Help
- SP700 Warranty
- it was all in the compression!
- Sportsman 700 color
- Help!
- Mike C..Help a friend,Help a friend.....
- 425 engine not right
- Will my 700 SP rims fit on a 2000 magnum 500?
- 700 OIL PRESSURE SENDER
- Installing a bored carb.
- 4x4 won't engage
- Sport 400/Trailblazer Pic.
- Wet belt!!!
- any one got the 35mm flatside carb on blazer/boss?
- atv fifth wheel haller
- Power?
- need info on scrambler and sport 400
- Whats the hp on a SP 700 ?
- Any 42mm flatside pointers?
- 1998 Sportsman info
- The Best All-Around Quad! Again?!
- transmission guard for broken chain?
- ack! need help!
- Attn: KNOWSALOT...
- Hub nut spec.?
- Tire & Rims
- Scrambler 500 4x4
- changed gearing
- Scrambler off the line bog
- Updated Pics
- sp 500 cv question
- Water pump
- Race?
- Quick Atv Shine!!**
- taking off safety stickers
- HPD Noise Reduction Kit
- Clutching
- Knocking out a old sleeve from a cylinder?
- Faulty primary E.B.S unit
- '02 500 scram hd rear spring
- Anyone else get a bum tranny on a Scrambler 400?
- Anyone use the HPD Super duty Clutch button kit?
- looking at buying a 2000 sp500
- Got whooped by Recon
- Problem with 4x4 staying engaged
- Not in Canada
- hp on a SP 500 HO & a 700???? Top speed & acceleartion???
- Starting Sportsman 335
- Polaris 400 motor
- HSP billet cylinder head.
- Scrambler auxilary brake problem
