View Full Version : Polaris
- Polaris Outlaw 450 to be let out of jail on July 22
- C-Series wheels on a 700 Sportsman
- Polaris 6x6 prices
- '05 700efi check engine light on-read this!
- anyone know how to remove the clutch on a 97 sportsman 400l 4x4
- Predator 500 2003
- reverse override mod 2002 scrambler
- hpd kehin draining fuel
- low end clutch kit-scrambler
- 500 ATP vs 660 GRIZZLY
- Water in the Intake on my Preddy
- Model Years and differences between 2004 & 05 Sportsman 700 EFI
- Temp gauge, what to get and how to install!!
- What about the hmf exhaust?
- What is the best after market parts for a predator 500?
- HPD chain tensioner question
- new trailblazer 250
- Your guys' opinion
- anyone have a $100 referal left?
- where can i find a digital tach/temp guage?
- Xplorer 300 - 4X4 not working
- Anyone else having problems with Recall??
- INCOMPETENCE EVERYWHERE FOR POLARIS PARTS.
- Recent events
- anyone try the HPD springs on predator??
- hpd valve springs
- Walker Evans Predator Rear shock
- Ride quality of Scrambler?
- 800 EFI clutch on a 04.5 700 EFI?
- Trailblazer exhaust
- Team clutch?
- needle jet adjustment for trailblazer
- sportsman 500 blown engine
- repacking OEM muffler
- shock adjustment
- Re-installing trany on 400 polaris question
- Insurance for atv in ma.
- Trailblazer 250 sticking rear brake
- NEW PRED TROY LEE SUSP SET UP
- 95 Scrammy In Good Shape, Worth?
- THANK YOU RICK RITTER!!!!!!
- 12" wheels and 10" wheels
- 700 Plastic melting with 800 header
- do you think scrambler plastic will fit on a sportsman
- Plastics Sport 400
- Goodyear Mudrunners
- Help! Used 2000 Sportsman 500
- Predator Subframe
- Mods on a 05 Trail Boss 330???
- Engine oil for 05 Predator
- help 95 polaris sportsman 400 4x4 help
- How much difference between winch makers?
- Crashed My Pred! Where is the Best Online Place for Parts (Steering Stem and Components)
- New member needs help with 92 Polaris 350 4x4
- Finally rode the Hatfield-Mcoy Trail
- predator hop up problem ,MODQUOD .help me, HPD isn't
- diesel quad
- Checking oil in Front Diff.-Xpedition
- pre mix ratio and recommended oil
- Help! Just bought Sportsman 500
- HPD Race Quad
- sportsman 500 how many digits in vin# 199?
- Be very very quite...I'm killing rabbits
- where can i find aftermarket plastic for 97 explorer 400
- need something to replace my pod
- need some help with 500 scrambler.
- Stupid ?
- Best 27"mudtire for ride quality SP800
- EDELBROCK PUMPER 4 PRED
- cdi problem
- vortex cdi
- front struts went bad
- jetitngand lights?
- '01 Xplorer Mod's
- Scary story
- Tach???
- new in the family
- 14" Polaris/Vision/Kenda set-up
- hole in crank case
- 06 polaris'
- Hsp pipe versus Dynoport for 97 explorer 400 trail mod
- HPD fuel pump,400 2 stroke?
- Weighed my 2005 sportsman 500
- What Manual covers the Diesel Polars?
- SWINGARM+AXLE
- What will give my 500 HO better throttle response & NOT void my warranty?
- 325 Magnum Crankshaft Info
- Car tach on my quad is it possible???
- Any ideas
- How do you remove axle from an SP?
- GPS MOUNT
- Best 2-place Quad Trailer? tilt sides
- Damaged 700EFI - Likely frame
- Any thoughts on re-usable oil filters???
- CRANKSHAFT THREADS? FLYWHEEL NUT
- 05 500 Seeping oil at filler neck
- noisy 2 strokes... quiet??
- Rattlesnakes, gotta love um'...pics inside
- is it worth buying the predator
- how much play in wheels on 800EFI
- Worn Tires.........Need some !
- First damage! x1 CV joint shield
- anyone have stock air filter scrambler???
- Grizzly or Sportsman?
- Everybody needs a new toy - this is too cool!
- Sounds like the Predator for 06 could be a racer!!
- Help please! Sportsman 500
- graphics kits for sportsmans
- choke leaks fuel
- 400 trail head compression testing procedure
- 800 efi on gas
- whats the loudest, baddest pipe around
- higher altitude and jetting confusion!!
- Mod trailblazer vs. Scrambler 500
- 04.5 500 HO 50th Anniversary Ed, What's it worth??
- belt life
- hot seat pipe jetting for scrambler 500 2005???
- pull starts very very hard causes antifreeze leak??
- sportsman 500 ho jetting???
- pred.500 V.S. honda trx450R
- 400 srambler owners engine problems
- Talked to Polaris!
- 1996 SP500 Loses power
- what jets and clutching will i need with new pipe
- 05 scrambler 500 water issues
- 2003 Sportsman 600
- 49.7 miles on 2.5 gals of gas :) 05 scrambler
- I won the exhaust!!!!!
- o5 700 efi oil change question
- Need a Sportsman EFI fuel pump
- Predator Crank3
- jetting
- CFM lowering blocks
- HELP for a Tach. and Temp. Gauges!!
- Happy with SP700
- Metal Shavings
- trying to decide
- white bros e-series nfg
- 2005 Sportsman 500 Questions
- 500 WATER PUMP
- It's been awhile - just wanted to say hello!!!!!
- Roll cage
- Problem with SP800 Brakes
- Excessive Gas Venting on 2003 Trailboss
- 96 Sport 400 Solenoid wiring
- Rear winch
- Polaris Predator carb tuning
- THINKING OF BORING OUT PRED TO 558CC
- Which carb was that?
- Work lights not working on Sp 800
- Where can i get jets for cheap
- Does any one know about the 2006 predator.
- Power Angle Plow
- Tech Question
- Predator -VS- Raptor 700
- Oil Changing
- Polaris scrambler 2 stroke or 4 stroke
- Goggles
- Got my storage cylinder and hitch installed, thanks ScramaDama!
- spewing coolant!!
- Front Bearing Problems
- Jet kit for trailblazer
- 700-800 EFI Ride Review?????
- brake resevoir leaking at lid
- Vibration
- looking for a plow
- 400 Sport Brakes????
- Need help fast!!! Exhaust system on ebay!
- Predater after market parts.
- DARN KEY TURNS OFF IGNITION
- solid state relay 700 EFI smoked
- front strut breakage
- lurching in gearcase but no metal pieces on drain plug magnet?
- Sp 700 ?'s
- K&N Air FILTER FOR THE 800 EFI
- clutch kit for 700
- nerf bars on scrambler 500
- ECM Safety Recall - Lots of Polaris'
- brake noise
- NEW 500 HO , man this thing is noise
- 500 HO 27" or 26" tires
- 400 trail blazer, sport & scrambler????
- rear hub (bearing) assembly-cone washer???
- The ole POOPlaris made me proud today
- mountian jetting??
- Anybody mounted a video camera to a Scrambler?
- Mud Paddles / Slingers
- Trailblazer head machining?
- to all 800EFI owners
- question on gearing my 05 tb
- Recall Notice
- NEW QUAD!!!!!!!
- Valve Adjustment
- Predator For Sale!
- Tire Repair Kits
- I smell gasoline in my engine oil
- SP 800 ATV of the year
- Another Scam
- atv's more popular than snowmobiles
- 2004.5 700 efi?
- 2004.5 700 EFI Transmission?
- Rattlesnakes, gotta love em', check out my pics
- Oops, flipped my Sportsman today
- belt whirl?
- Fluids
- Where does this go?
- how to use clutch alignment tool.
- Polaris scrambler 500
- 250 tb,needs more bottem end herd somthing about clutch kits
- Matt Smiley
- own a trailboss?? I NEED YOUR HELP!
- MODIFING STOCK EXHAUST
- What RPM does your 2005 SP500HO Idle at?
- TB400 pipe on a TB250?
- HELP with 600 rear axles
- Idea from previous post about mods and video game!
- secondary roller clutch question
- help!!! trailblazer keeps dieing
- goodyear belt
- A New Electrical Gremlin
- RAPTOR 700 will it be the new king?
- Help with trailtech speedo.
- why do the front tires vee out?
- 3WD Honda is better than a no AWD tank
- 1000 posts!
- Dumb Question: Where do you fill the oil?
- 400L limiter rpm module?
- stupid 4X4 question
- 2004 Polaris service manual questions - just got mine - no CD?!?
- Headgasket?
- Is hub oil really motor oil?
- New Gates belt HELP !!
- What's my stock rev limiter set at
- How do you guys like my new Mini Tach
- New Sport quad for Polaris!
- Anybody gotten the footboards LineXed?
- Swing arm bushings????
- THE POLARIS DIESEL ATV, IS IT POWERFUL?? AND WHY STOP MAKING IT ?
- IS THERE SOMETHING WRONG???
- Paiute Trail trip
- Water Pump Gasket Fix
- i am pissed!!!
- Plow blade instructions
- polaris scramber 500 4x4
- polaris screwed up with this one
- Can we solve the starter problems!?
- stop the winch before it breaks??
- Predator mikuni BSR 42mm
- Polairs Diesel - Now Roush bring out one for Nato.
- adjust carb on a 335?
