View Full Version : Polaris
- Sportsman second radiator has anyone made one?
- Concentric VS Non-concentric?
- 2000 sportsman 500 internet parts cheep
- Sportsman Bolt pattern
- Enough power to pull ????
- Predator motor blown up, can anybody elaborate?
- Polaris parts
- found cheep rear rim option for scrambler.
- Rezzies....
- weird electrical prob
- Trailblazer 250 Spring Help
- 700 efi need some help
- 03 Sportsman 500 HO
- Xplorer sometimes pulls hard to the left
- Jsut for fun.
- cooling question
- Scrammy 500 shootout and 800 efi review
- scrammy 500 pipe.
- NEED JETTING RECOMMENDATIONS!!!!!
- 87 polaris cyclone help
- Rear Gearcase oil question - '04 700 EFI
- MODIFIED 700 VS STOCK 700
- 2000 sportsman 500 coolant overflow
- 700 sportsman racks
- 98 Sportsmen ?
- 04 sportsman 400
- Watch out Poo!!
- gonna get a new 04.5 sp 700
- No Spark Nightmare
- Wish me luck....
- Scrambler broken shift handle
- my 00 trailblazer smokes with the synthic oil
- cv yoke
- Worn tie rod ends
- Oil coming back through the airfilter??
- woooohoooooo!!!!
- Best 250 trailblazer price
- BEST PREDATOR PIPE?
- changing front springs
- Plug Wire on sp
- Has anyone built there own accesories for sportsmans?
- Radiator screen?
- scrammy is bogging down in top end??
- Raising the hood on a 2004.5 500
- Wiring diagram???
- Good Mods
- scrambler on 20's?help me ideas
- 2001 Scrambler 90 not running
- 330 Magnum hard to start
- What good mod should I buy?
- 04 500 spark plug/carburator problem?
- A couple questions
- HELP! Electrical short? 99sprts500 after plugging into front accesory port.
- jetting a uni air filter?????
- Hey...bring my Sportsman over here.....
- race lightened flywheel
- where is the clip in the carb!?
- Elevation and my 2-stroke
- sportsman 400 mods
- Tomorrow is the BIG DAY!!!
- New carb for the Boss
- scrambler tires size
- Anyone ever do this?
- Stock driven clutch spring setting?
- BBS HELP!!!
- did not like polaris that much until i rode the 500 scrambler 4x4
- Busted rear boot with some clicking???
- 2004.5 Sportsman 500HO home made skid plate?
- When ordering predator plastic look out !!
- cooling fan,'99-'00 sportsman 500
- best clutch mod for scrambler.
- Does FST make a bbk or stroker for 500?
- Sportsman 500 Pulled by an Outlander 400
- Polaris 500 Charging Problem....HELP !
- Sportsman 700 04.5 steering?
- front drive "differential" in 04?????
- Race Logic Porting
- 2005 Pre-wired Winch installation
- 98-97 same frame???
- Scrambler mods!!!!
- Polaris Sportsman Spark Plug Wire Known Issue
- New to Sport
- Where do the girls post?
- predator owner ?'s
- Lights dim at off idle engine speed
- All Pred owners, check this out, engineer needs some help....
- How to use a forum
- what air filter
- 400 cylinder differences?
- EFI RPM question
- scrambler body swapping?
- gearcases, low range or not.
- IRS Shock Adjustment
- new Predator recall?
- New heavy-duty tow vehicle
- 04 700 efi
- 04.5 SP 700 EFI leaking axle seal+metal shavings
- Need a little bit of HELP
- Best place for Scrambler 400 parts?
- clutch cleaning
- Sales figures
- 1997 Sport rear shock
- F.Y.I Trailblazer tranny swap
- Scrambler Help
- 400 Sport Lights
- How fast is a 01 trailbalzer DG?
- helping out with my uncles 400
- 95 425 Magnum 4x4 , some questions
- 04.5 FENDER FLARES ON 03 700 SPORTSMAN
- cv boot
- 4wd Problem
- 04.5 sportsman 600 take off power?
- Need a new belt... HPD belts any good??
- wiesco piston?
- Lowering the pred, by means of cutting the subframe.....??...
- 2005 Sportsman 700 EFI Evaluation
- Question for Western Slopers
- come one come all!!
- 04.5 Sportsman 500HO soft front end fix: NEW springs!!!
- Kenda Bounty Huntire tire/rims???
- ITP 589 tires and C series rims for sportsman 500 2004.05
- Looking for a Primary Clutch 400 Scramberl 4X4
- Sportsman 700 wheel bearings SMOKED
- 02 sportsman 500ho belt
- Wobbly front end on a new Sportsman 600
- whos going to get the big 800cc
- fcr on predator
- looking for front tires for my 400L sport.
- Got a belt slipping problem...
- pred and nos??
- Heelcliker cluch kit
- More from Doug Nicholas's shop(pred motors)
- pred ebay items
- Buying used scrambler, which year(s)?
- Swingarm guard for Trailblazer 250
- head bolt torque values
- Anyone used Pure Sports Realtor rear tires?
- injector cleaner in fuel. 2 stroke and 4 stroke.
- Need some expert help..with Sp 500 HO..
- Tranny upgrade works great on 03 predator
- Brought Home (2) 2005 500 bikes!!!!
- Scrambler 500 4X4 Near Sacramento Ca.?????
- Front Diff on Sportsman
- Need new front plastic for Pred.
- T.B. piston size
- I saw the 05s!
- Crash!! and scramblers are tough
- Anyone with a 05 Predator!!!!!
- trail closed for good!!!
- Oil Leek from the weep hole?
- Fin Dampers
- Hard Box
- Hi all, New member and 3 headlight ?
- put the pipe on and....
- Happy RAJ!!!!!
- wheeloes (automatic)
- Upgrades for Trailblazer 250
- crackedmy swingarm
- Front hub on sportsman 500 HO
- whys it keep eating bearings!!!!!!
- clutch question
- Is replacing a cam a difficult job?
- 4 wheel engine braking
- White Bros pipe and stock heat shield?/ predator
- Scrambler help!!!
- a gazzilion questions about my pred
- EBS w/ Override Question
- Tire Chains
- Clutchkit (Yes/No)
- Rear Shock Adjustment
- Carbeurator/Jetting Question
- what should i get?
- Is Warn 3.0 install an easy Saturday job?
- Question on Maintenace
- shifter stuck
- Updated my web site pics...2004.5 Sportsman 500HO
- Sportsman Exhaust leak
- New WARN winch will not free spool?
- xplorer 400 4x4 vs scrambler 500ho 4x4
- 04 SP 600 Ignition Switch
- First Time Caller
- Sportsman 700 04.5 tires?
- one last time. scrambler 500 verse 400 acceleration not top speed.
- 98 Polaris Trail Boss 250
- Octane additive in 2-stroke?-WARNING
- Scrammy starter problems
- Pure Polaris 600/700 silencer tuning?
- Bull gap sand hill results...
- Is this the new 2006 sport quad ????
- Polaris 500 Front Wheel Bearing #s???
- jetting to run
- 700 SPORTSMAN VALVE ADJUSTMENT?
- 700 SPORTSMAN BRAKE NOISE
- whats the reason??
- GOT GOGGLES???Lets hear about em!
- Pred Tranny update kit
- post your
- down to the frame tear down
- How many of you Predators will make it to the WORCS race next week???!!!
- Polaris trans.
- Sportsman in the snow?
- Journeyman machinist looking for work.
- When are the unannounced 2005 coming?
- Sportsman 500 question....
- 2005 Predator has (2) 500s!!!!
- your thoughts
- Polaris Red Paint?
- I know, I know. The never ending Scrambler Tire question
- Think he has a chance? Buuwaa hahahah, I don't think so.!
- Had the cold start update done to my 600, muuuch better!
- pred crank case vent
- shims
- w00t..part came in today
- sportsman 335
- handlebar shake
- Axle Boot options?
- I saw a 05 Predator 90 today!
- difference in gas mileage from 500 HO and 700 Carb twin
- Quad - Rear Diff - locker, spool, other options, help!?!?
- Finally ordered my shocks!
- woodsracing
- new 03 Predator $5000...Good Deal?
- Changing cluches in scrambler500
- foun 5 scrammys things to look for when buying and comparisons.
- Need new plastic !!
- hot seat jetting
- Timing marks ????
- 2005 Sportsman
- air preasure in tire problem
- HPD spring kit finally set....how is yours set??
- 2003 Scrambler 500 4x4 Transmisson ?
- 2005 TLD Preds, a couple questions
- magnum 330 4x4 fans
- Lost private message (spring spacers)
- How do you like your predator? Pros/Cons?
- Performance CDI Boxes
- Starting problems. Any advice?
- scrambler 400 need tires??
- What would it take for 700 scrammy?
- Need Clutch help bad?? Please help??
- Got some ship dates on some 05's-not good
- Pred Chain/Doug's Sport
- Haydays
- 05 predator
- Do all you guys always Pure Polaris 2 stroke oil?
- roller clutch ???
- Holeshot Hypershift EBS clutch kit for 500HO Sportsman
- RCR apperal???
- Sportsman Speedo
- RCR stage 1 website?
