View Full Version : Polaris
- Who knows primary weights?
- Ok...would I need to get new springs?
- PVT Air Duct Mods
- Clutching Paradox
- Clutching Paradox
- Hi-Performance?
- Where can I buy tires?
- Fox Struts from Polaris 20% off?
- Big Bore Piston
- Honda Bashing?
- GPS speeds???
- horsepower
- Alloy bumper for the 2001 Scrambler 400
- scram 2001 500 2x4 comments
- warn winch on a sportsman90
- sp500 steering help
- Tech Help (98 and older 4x4's)
- Check this site out!
- spark plug
- Magnum 4x4 325 or Rancher 4x4 350ES
- 2003 Honda FourTrax Rincon
- Handbook or technical manual
- gas to oil ratio for 95 sportsman
- 2001 SP500 HO - Override Button ?
- Help me with keeping the front end of my TB up on jumps
- Saw a Scrabler X 400 4x4 at my local fair.
- Plain black Plastic?
- Winches? - Warn vs. Superwinch - is Superwinch decent?
- Changing front sprocket on `98 Xplorer
- HD Front Springs
- Dynoport Pipe/Silencer Co.
- My sportsman spuuters in deep water??
- scrambler plastic?
- new polaris sport quad!!!!
- spitting and stuttering, please help
- Will a Sportsman 500 fit in a Ranger/S-10?
- calling kukerdan
- 00' Expedition 425 4x4 (Is this a good machine?)
- New Sportsman HO "X"
- Scrambler 400 X 4 x 4 !!!!!!!!
- HPD REED CONVERSION
- Help! - Popped Front Drive Shaft out - Polaris 2K1 500HO
- Rails for racks
- Yo , Dazed, I got a Question for ya?
- Any websites with winch photos for 700 Sportsman??
- A-arm guards and skid plate for Sportsman 500
- Bernbanger 400???
- My new pics
- scrambler 400 transmission infos
- After Market Skid Plate????
- Polaris 700 Twin sighted....
- Loose hub on my Scrambler 4x4
- Sportsman 500 h.o -- MPG
- tie rod ends
- Seasons Over
- HP Rating
- Tires
- Hi All
- Dirtwheels Shootout
- sportsman90
- 4X4 AND REV LIMITER
- New HPD Pipe on Scrambler 500 4x4
- xplorer 400 good for mudding.
- Engine Compression?
- Whats wrong
- Plastic
- Does the new 700 have a different rear suspension?
- Isn't Heavy Sometimes Good? Hope I like my Sportsman 500!
- Anyone with a Scrambler 500 race a Prairie 650??
- Jimmyrigging
- HELP! HELP!!!!!!
- K&N Filtercharger
- I have a new site!
- 89 trail boss question
- Polaris Extended Warranty is Poor
- Magnum 325 4x4 Speed and Dealers
- I've had enough!
- '99 500 Scrambler 4x4 air/fuel mixture screw!!
- Plowing with ATV
- 2001 Scrambler 400...
- '01 Sportsman HO or '02 Magnum 500..
- Scrambler Rear Brakes Dragging?
- Sportsman 90 performance
- Tommorrow is U.S. Color day.
- Which quad is right to turn into a "Mudmonster"?
- polaris break-in oil? is there such a thing?
- Any problems with the HO's
- New Rear Brake Setup
- Scrambler 4x4 HPD Pipe
- New 2001 Mag 500 for $5500 or 2001 Sp 500 H.O. for $5900?
- how fast???
- Stock jet for a 2000 SP500???
- After Market Oil Filter, Don't do it
- scrambler 400 rev limiter?
- Found good tires for 250 Explorer
- I Love the HO's
- SandTire Air Pressure
- As a New Zealander I am devastated
- Will someone please look at this starter brushing???
- New WTC Building Idea!
- scrambler 400 case reed clearance?
- grey plastic???
- Rear Rotor Replacement on Scram???
- DON'T FORGET TO GIVE BLOOD
- what is a fair price for a good used 2000 trailblazer?
- World Trade Center and Pentagon
- 99 Sp550 tierods
- difference between a 2002 scrambler 500 4x4 and a 2002 scrambler X
- Atvmn Ride this weekend near park rapids Mn. Who is going???
- 335 is still pulling
- 2001 500 H.O. question
- Tires for Scrambler 4x4
- which is the fastest
- 1991 350L 4x4 carb problems... HELP!!!
- CV BOOT REPAIR.......Help......
- Stock market and this board!!!!!!
- Perry APV in Ohio
- Chain and Sprockets Specs for a 99xplor 400
- 250 race pipe?
- Another one for 'ya
- Voodoo poonani..
- Now 3 Sportsman 500 HOs
- 400 sportsman aftermarket rear rotor
- need belt
- Scrambler rims/tires
- Scrambler 500 4x4 vs. 400EX !!!! Help
- 1997 Sportsman 500 Good and Bad?
- scrambler 500 4x4 for me ????
- Aftermarket or OEM sprockets?
- looking at used '99 Sportsman 500
- Idle adjustment?
- cv joints
- DAMN DEALERS &PARTS MANAGER AGAIN
- parts
- Speed in low gear
- Gas leak on 2000 325 Mag
- Going to Badlands in Attica, IN this weekend who will be there?
- Alcohol
- Factory wheels & tires
- Tightening front chains
- BERTS DIRT WORKS !!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
- 20hr checkup (please help)
- 700 Sportsman in stock now!!!!!
- Has the 700 lost weight?
- When do the 2002 models hit the floor?
- Should I drain my gas tank?
- Any of you ported before?
- Polaris Explorer Is Very Top Heavy
- Axle bearings...
- Another 700 question?
- Refill struts???
- Way way way waaaay too heavy!!!
- Looking for someone to ride with
- Carb Help??
- Polaris is trying to fool us!
- RCR Stage 1 Kit
- chain tightning precedure???
- Grizz 660 beats 700 sportsman in a drag.
- new belt cover
- How long will the brakes last on my Scrambler?
- Sportsman 335 Charging System
- 400 sportsman 2 stroke need tech help
- Sportsman 400
- 500 HO noise?
- Sportsman plastic bumper turning white
- Private message from 99griz
- HELP! Tapped on starter. What does it mean?
- New to forum!!
- Questions about the Xplorer 400's.....
- Steel braided brake lines and older models
- Scrambler 500 Carb Leaking!!
- RODE A 700 SATURDAY......WAITING FOR MINE :)
- No spark on HO
- Clunking sound from front right side when backing up? Any idea?
- Driven Clutch came apart!!!!
- doesn anyone have SCRAMBLER headlights they would like to sell?
- do you want get rid of the clicking noise in your 500ho
- Scrambler 400 4x4 X
- upgrades for trail boss
- 400 scrambler muffler?
- '99 Scrambler 500 4x4 mods
- Best factory parts prices & service.....where????
- SP700, my take after the ride
- scrambler hub problem please help!!!
- ANYONE WITH A ROCKY MOUNTAIN CATALOG, PLEASE LOOK THIS UP FOR ME...
- Scrambler tires?
- GUYS! I NEED YOUR OPINION, PLEASE READ, I THINK THIS IS BETTER THAN MY OLD TIRE PLAN, HELP ME OUT HERE......
- battle of the big bores
- One more Sp700 question won't hurt
- Can anyone confirm if there is a sp700HO coming???
- 01 325 Boss and White Spring
- My dream quad from Polaris!
- A 700HO by October?????
- POLARIS WEB SITE UPDATED
- Scrambler X review!
- Red White and Blue SP700
- Camo Clad Use???
- why doesnt polaris make a sport quad
- Overheating 400
- Need a price on a right front strut housing/spindle for '01 Scram 2x4.
- The truth,you cant handle the truth!
- sportsman vrs sportsman H.O.
- Limited test ride SP700!!!!
- KAWASAKI AND SUZUKI MERGER ???????????????
- PSI?
- Sp700 vin#1 First Ride
- jacks forum
- Polaris Adventure Tours in October
- Riders from Ohio and N.E. Pennsylvania
- Epi clutch kit (JUNK or NOT) ???????
- 500 Muffler/pipe question.........
- ACTION ALERT
- I saw the VERY FIRST Sportsman 700. It was vin #1
- Sportsman 500?
- Polaris snowmobile discussion forum?
- starter on 400 scrambler 4x4 1999
- 2 stroke stalling when hot
- FMF silencer on RCR pipe
- WHATS THE BEST PERFORMANCE MODS FOR A SCRAMBLER 500 4 STROKE???
- Should I be scared to buy a Polaris???
- Explorer or Scrambler transmission can they take 80ft/lb's of torque?
- If you don't like Polaris Stay Out
- ATV pulls in Maine results!!
- eliminating battery?
- Torque of sp 700!!
- Sportsman making Very Loud Squeak in Front Suspension
- Need help. When will ATV flip over?
- Yahoo mesanger screen name
- AOL Screen name
- Hey Rick Ritter, could I bother you for a moment?
- Help with a TrailBlazer Starter
- Still losing Roadless Initiative letter Battle 6 to 1. Deadline Sept 4.
- Dynojet kits
- what am i going to do about tires for my scrambler?
- Do you know why ???
- I hate to do it but yet another rumor
- How did we all get HOOKED?
- Good Canadian Parts site here.
- Electric Starter.
- Problem with xplorer 400
- sp700 and snowtracks
- The sp700 does have a Better Hp/weight ratio than the HO!!
- 01 Trail Blazer Problems
- Scrambler starter
- swingarm bushings shot?
- Sportsman aftermarket shocks
- Crashing sucks. Need some help.
- online parts
- Dangers from modifying non H.O. into an H.O.sp500
- the 2003 sp700
