View Full Version : Polaris
- weld wheels?
- Dune tires
- Spruce Green 700 Sportsman Pics?
- 2002 Scrambler Down Hill Question?????
- Question for Mod Quad
- COOLANT LOSS ON THE SP700??
- upgraded brake lever and master cylinder??
- Wider tires on front of Scrambler
- feedback on epi clutch kit
- Lumber wagon no more!!!
- anyone have cool head
- Does Polaris make any...........
- Aluminum front bumpers for scrambler??
- Keep or ditch plastic heat shield??
- Scram. Speed
- sp500 tires on Scrambler
- clutch kit
- Help! Water in SP 500 Belt Housing!!!!
- Need advice on aftermarket pipe
- Pulling right
- Scrambler 400 Speedometer
- Clutch Springs and Belts
- 400 xplorer engine???
- New Pics..... sand, trails, mud, jumping, all on scrams
- chain adjustment??
- question about polaris starters and rear shock
- Anyone have AOL Instant Messenger, and want to talk?
- TRAILRIDE
- sp500 help please
- 89 trailboss question
- Are Polaris 2 strokes being phased out this year??????
- Warn 2000 to 2500 upgarde kit?
- Scrambler 400 4X4 hubs?
- clutch buttons
- Strut housings?
- New mods,, but which carb??
- What do you giys think of the Trailboss 325
- Where's Steering Grease Zerk On Sp400?
- GOT A QUICK QUESTION, IN NEED OF AN ANSWER!
- Sportsman 500 Front hub oil how much?
- scrambler 500 4wd pros and cons
- will a scrambler beat an ex or a warrior?
- sc500 jetting
- Tech Help
- cooling fan not working on SP500
- Lightening TB
- Confused Please Help
- Does anybody have Clutch kit on a SP500 from RCR?
- Polaris Trailboss
- RCR Stage 1 Kit is installed!
- "Limited Edition" Production #'s?
- Oil Injector Gear
- What color spring?
- Buying Polaris in Canada
- Scrambler "Wheelie"-bility
- Dirt Wheels Magazine
- Advice regarding Sidewinder Chain
- Advancing timing on 700
- It's too loud!
- Question about Stage ! RCR?
- SCRAMBLER 400
- Another S.E. 500HO
- Any suggestions, old magnum mods?
- Scrambler 400 with Wiseco 0.50 and suspension
- 500ex 4x4 or honda 400ex?
- Throttle Freezing Up What to Do?
- what do you think of the TRAIL BLAZER
- "GOOD" Polaris 400 engine story.
- scrambler are junk
- STROKER KIT FOR TRAIL BOSS???
- Speedometer/odometer for Scrambler??
- colours
- Anybody else feel like they bought a Friday @4:00pm bike?
- sp700 accessories
- Pipe and jet for Sportsman 500 worth it ????
- What would be your second choice???
- scrambler 500 4x4 clutch springs
- Riding a Polaris in North Carolina!
- Big Bore fuel consumption, who is the best on fuel.
- Sportsman or Kodiak?
- Frozen Struts
- HELP!!! Scrambler 400 4x4 or 500 4x4
- New ATV
- 1992 250 I think Trailboss
- Need a Muffler for a Sport/Scrambler
- Another Limited Edition SP500
- Sprtsman rear drivetrain u-joint tip
- 2000 400 Scambler 4x4 CV boot
- Send me your pictures...
- # of ATVs sold?
- 88 trailboss clutch problem???????
- Who else is sick of Prairie Bragging?
- any riders from iowa nebraska or missouri
- Trail Blazer Paddles
- Need to beef up my boss!!
- Just Curious
- pipe and tires for scrambler 500
- Scrambler 500 - Clymer or Factory Service Manual?
- scrambler or maybe something else
- Airbox Mod ?'s for 400
- 89 trail boss??????????????
- More carb tuning ?s
- Pipe for 400 Scrambler
- Polaris Sport Quad?
- 96 400Exsplore mod. tips
- New to Board
- Scrambler Backfiring, and Carb Bogging. -No throttle response!
- scrambler is gone !
- 01 trail boss good or bad
- riders pictures
- need more kick out of my 500 scrambler
- Can Someone please fax me Scrambler/Sport Information?
- new polaris shop and kawaski and suzuki to open in council bluffs iowa
- Torque specs for primary clutch cover bolts
- BIG Spring Ride in Tennessee
- DG aluminum grab bar
- sc500 what a pain to change spark plug!
- Are Sportsman's reliable?
- snow in nebraska and iowa 10 inch scrambler was bustin drifts
- Canadian Atv prices
- secondary spring
- need wiring schmatic on 88 trailboss
- BOSS NEEDS MORE PUNCH!!
- Parking-brake for a SP 500 available?
- carry or pull?
- Painting my frame, need your opinion
- Who here runs Nitrous? (NOS)
- exhaust
- SP700 or Scram 400 4x4 X
- gas gauge for sp 500 h.o
- Mudrunner Size Q?
- 2002 Dodge Ram
- Sportsman 700 Fuel Leak
- trail boss 250 mods
- Frozen starter
- Split brake kit
- Knowsalot,Please help Stinky
- water in counter balance again!
- Clutch kit for hpd moded scrambler??
- Filtercharger on a Scrambler?
- 2000 400 SCRAMBLER 4X4 MODS
- Rick Ritter (rod Knock)
- A few ?'s about the 700Twin
- A Question for Todd400
- 250 Trailblazer Mods
- oil in air box...has this happened to you?
- Anybody familiar with Sundiro youth atv's?
- Different hubs on a stock polaris Axle?
- Where'd my throttle response go?
- Vote for the 700
- Cooling fan problems- Ditch it, or not?
- Anyone adjust the oil pump on a 400 before?
- Bearings and Seals Sport 400 (Rod Knock)
- Big Bore shootout includes dyno numbers and drag results.
- Todd400
- 99 sc500 makes popping noise and chain will loosen or tighten
- What weight of oil is in the external tranny of 400?
- SPORTSMAN FRONT HUBS LEAK?
- Polaris Warranty
- suvere brakes
- electrical on 89 trailboss
- Jetting with K&N
- what does getting scrambler seviced involve...
- Hot Seat Rear Hubs...Anyone Use Them?
- 00 sp500 clutching problems
- Sport 400 Rebuild and Oil question.
- Anyone Tried a Dial A Jet on their carb?
- Cheap Mods or Tricks For 2001 Sportsman 400??
- Do You MX?
- Suspension & Handling Mods-Scramblers & Sports?
- TMX or PWK carb for 400??
- explorer 300 questions
- Scrambler 500?
- Sould have stayed Home!!
- Pictures of my 700, this week-end, on ice and snow
- Polaris Transmissons
- cams and rockers
- Protecting the SP700
- new 700 colours
- spraying polaris down with wd-40
- SP335 Transmission Question
- SWEET WHEELS
- rear hubs
- Cheapest Place to buy a twist throttle
- What makes the DIRT DEVILS so great?
- Wheelie trouble
- Anybody have a sportsman 400?
- got the trailblazer to wheely
- chain tension is inconsistant.....why?
- EBS Kit
- Four stroke motor mods
- Sunk my 00 SP500, Please help!!
- Best Canadian price for a 700 Sportsman
- Tranny fluid??interchangeable
- NOS
- Site is working now!!
- Disappointed with Dirt Wheels Mag.
- Magnum 500 RMK
- Head got alot hotter than usual???(Please Help)
- Which Direction do I want to go with my Quad?
- HELP, AWD override unaccomplished !!
- More Power for 500 H.O. ?
- '01 HO shifting problem
- SP 335 Warm Up
- Replacement of Needle & Seat of '01 Sportsman 500 H.O.
- Scrambler's front drive is out?
- First Valve Adjustment
- Clutch springs
- Scrambler VS Banshee or Raptor
- Scrambler plastics
- Water ingestion
- 500 HO in Xplorer?
- oil in airbox on sp500 bad?????????
- Polaris Sportsman 400 or not?
- Pushrodaphobia
- Gave up on polaris and now Have new 2002 Wolverine! Will it handle 25" tires ok?
- 700 Oil Filters
- Does anyone have some Scrambler headlights?
- found out why no spark on xplorer 400
- Servicing a Trail Boss
- Where to get Polaris Plastic?
- HPD Roller Clutch - Broken Rollers anyone else?
- Scrambler Swingarm bolt comes loose!!!
- 500 HO reverse button
- Jetting a TrailBlazer
- Radiator Problem Please Help!
- Magnum Power
- Polaris 700 Sportsman?
- Reverse AWD Override Accomplished !!
- 425 Mag 4x4 problem
- No AWD?
- RPMs
- scrambler belt
- How to convert a SP 500 HO for road use only?
- Which Clutch kit/springs?
- SITE UPDATED!!!!
- Scrambler 400 4x4 top speed?
- Got my Xplorer 400 Back Together
- rebuild a scrambler 500 and 400/ tire selection
- Online Parts?
- Trail blazer clutch weights??
- Does anybody know where to get heavy duty springs for sportsman 400
- Sportsman 400 vs. Kodiak
- Split Brake for 2000 Scrambler
- Disconnect reverse and 4wd overide
- Xpedition 425 4x4 5 speed i need more power help
- 2002 Xpedition 425 4x4 ground clearence
- Small design flaw for Sportsman 700?
- Plastic racks
- break in
