View Full Version : Polaris
- 01 Xplorer / Losing Coolant / Bogs down
- found oil in air filter cover?
- Owners Manual or Service Manual, which is right?
- Brake Fluid Leak
- concentric chain and sprockets for scrambler
- Gel Battery
- 1999 sportsman 335 problems
- Slow Oil Leak Sportsman 500 efi? Help
- shocks problem
- cams or p&p?
- Graphics and seat covers ?
- Leaking Brake Fluid
- 400 dyno results
- my 06 sportsman 500 efi still missing and dying!!!!!!!!!!!!!!!
- Just got 700EFI....Have a few questions.
- Lock-n-ride backrest for Hawkeye
- Help with fluid changes 2001 Sportsman 500
- 400 sport mods
- 04 scrammy.. thinkin bout takin 4x4 out to drop weight.. thoughts?
- Need wire wiring diagram!!!!
- sunpro tachometer
- Removeing a primary clutch on a 04 500 HO carb.
- what type of engine oil to use in 500ho motor??
- Scrambler 500 cv boot repair
- polaris vented gas cap
- adjusting idle
- 2003 Polaris Predator
- Would you buy an 06 Hakeye 4x4 ?
- Sorry, below should read HAWKEYE, duh
- scrambler 500ho oil change
- Hatfeild mccoy west virginia
- O.K...common way to change oil!!!!!
- 2004 polaris service manual
- going to add the rad. additive
- Oil pump priming necessary???
- common problem with the predator 500
- BAD NEWS ABOUT THE OUTLAW 525
- X2 Ready for breakin maintenece and BROKE ALREADY
- Poor little Light-Buoy that lost its way
- Engine gurus, a question... (particularly Pred guys...)
- 96 Trail blazer opinion
- Has anyone...
- 250 trailblazer quits running
- polaris oil filter number?
- How to get screws out of float bowl?
- Battery elimination
- 2004 sportsman & 2002 scrambler both 90's what parts swap?
- God D@*& CV boot... Help.
- Predator rebuild ???'s
- Well,I wrecked it....
- Sportsman 500 AWD?
- Strut question
- 800 radiator
- sp 800 vs bf 750 speed
- highlifter gauge
- problem with the sportsman 500
- 99 scrambler 400
- Polaris Sportsman 800 Vs. Outlander max 800 LTD???
- 800 Sportsman owned by Prairie 360
- wont idle
- 500HO or 500HOEFI
- air filter....sp450
- 1998 Magnum 4x4 Override & 4wd not working
- temp gauge
- Predator Procom CDI box
- white bro exhaust
- Best pipe for Predator??????
- polaris lover
- scrambler plug wire
- Battery drains...
- K&N Clamp on
- melted line under carb
- 400 Sportster plastic tubes in steering column
- Need help with belt or clutch squell with 800EFI?
- 600 twin. Why dont they make em anymore?
- Predator oil level
- Check Engine light--500HO--2006
- I'm going to try the Dynoport on my TB250.
- Trail Blazer Recoil
- Installing a winch
- just bought new 800 EFI
- 2001 sportsman 500
- flooded my 500 ho
- Low Idle Speed
- pred air box?
- sp700 tires on sp 500
- 2000 Polaris Trailblazer Silent Chain
- rolled my sportsman
- rear brake line/extended swing arm
- Scrambler 500 4x4 quick question.
- Oil Cooling
- Rolled her..time to rebuild
- hard starting
- New Predator owner???
- What is..ADC (Active Decent Control)... ??
- 99 250 recoil spring
- 93 polaris wiring diagram for 350
- pure polaris pipe
- engine coolant change
- Radiator Fan Question ~?
- Sportsman 700 wont keep running
- 800etf HOT..melting plastic
- Car air filter for the predator!!
- 2006 500EFI
- 6x6 Tie Rod bent like pretzel
- 06 sportsman 500 cv boot
- Would a Polaris Predator 90 be too large ?
- 07 Predator 500 or 07 Predator 500 LE
- Break in secrets
- Pull Start rope jammed??
- Need a website??
- minnesota ride red top
- Which Polaris would you buy for your wife ?
- 1995 Xplorer 400 Oil leak. HELP ASAP
- polaris steering problems
- sportsman 450 repect
- radiator additive
- first problem on the 800
- coolant coming out reservoir tank
- Need Help with Part!!
- Predator reat break problem
- '05 800 EFI fuel pump
- help with intermitten starting problem
- Looking for a clutch kit for a modded 98 scrammy
- sportsman AWD problem
- Predator 500 valve clearance?
- 2002 Scrambler 500 gearcase oil amount?
- What do you think?
- Pred 500 CDI, Help?
- Need rear skid plate - Scrambler 400 - suggestions?
- web cam or hot cam?
- HELP RE: Polaris BodyGuard
- aaen had outlaw 525 in shop made pipe
- Proper lift kit
- Used 05 500ho for a used 05 predator?
- Polaris trail blazer or banshee
- scrambler 500 high output
- predator rear tires
- SP 800 bad idle and no power
- 2001 sportsman reflecter
- NEED HELP FAST ON PREDATOR 500!!!
- Any polaris's going to Lil Sahara Drag Aug 18th
- looking for part #s
- pred 600cc stroker kit
- New piston HELP
- The Scrambler Killer Has Been Born!
- 04 sportsman 700 twin top speed
- '03 Sprtsman CV BOOTS
- NO Electrical Power
- How to fix this tank?
- Yeah you guys 4x4? I got 3 Wheel Drive!
- 700 efi
- Performance exhaust systems - Tail Boss/Sportsman 450
- Trail Boss - Chain keeps coming loose, axle clamp turning
- Rear Axle Bearing Dilemma, Need Your Thoughts
- 500 ho hard to crawl over rocks?
- whats the difference in brake fluid
- The Polaris Tire Exchange
- How do you change bearings and boot
- 05' Sportsman 500 Gun Rack
- Predator intake options / performance (any information)
- outlaw 525
- Original Warranty Extensions
- 1996 Sportsman 500
- downloadable service manuals
- Southern PowerSports of Chattanooga
- anyone use pull starter
- predator front noise
- New Scrambler Graphics
- HAWKEYE CV BOOT REPLACEMENT ( 2nd Try)
- 700 MV rear springs...
- Predator Dial a Jet?
- 1999 Polaris sport 400 Clutch spring
- 1999 Polaris sport 400 starter?
- 99' Scramber 400 starter
- 500 sportsman ho howling noise while moving
- CRASHED = bad armature in front hubs (Scrambler 4wd)
- Predator Cold Air Intake!
- SADNESS PREVAILS
- muffler rust?
- Tire rubbing tie rod end
- flyweel removal
- 330 Mag cooling fan
- compression on a 300 xpress 2 stroke
- 500 ho sportsman speed help!!!!!!!!!!!!
- mudwiser tires
- Black and White Primary Spring
- 800 pipe falling apart
- Hand shifter stuck...
- GPS for ATV ASAP
- Ignition Key Fitting Multiple Quads
- KTM 525 engine in the Outlaw!!!!
- Melting plastis 2006 500
- 700 Info
- 2001, 500ho sportsman Speedo
- Best pipe for a Predator?
- Looking for help on 2004 700 EFI
- 05 Scrambler Water Problem
- 98 express wiring
- Sportsman 400 drive clutch bad????
- coolant issues
- What kinda gains
- Hawkeye CV boot repair
- Looking at options for 96 Sport
- Scrambler Battery?
- 2005 Trail Boss - Loose chain problems and axle issues
- Predator 500 Tires?
- help with starting problem 300 xpress
- Extended Warranty, Worth it?
- Scrambler Rims
- no Spark 1998 Scrambler 400
- Help on a 99 335 cv boot
- br9ES on race mods 400
- Trail blazer clutch
- AWD engages by itself
- oil changes after 50 Hours.....
- 85 Polaris trail boss wiring diagram
- 600 sportsman HELP won't run
- tire reviews?
- coolant in air box
- polaris
- Magnum 425 not charging
- Two Cycle Oil
- Tire Pressure for Maxxis Tires
- X2 fuel tank in a sp800??
- Beat the Heat mid summer Sale
- Fabricating a rear shock?
- 1996 trail blazer Exhaust
- SP 450 - Rear brake seems like its not working
- 05 700 EFI melting
- Scrammy's vs. Pred's or Outlaws
- OUTLAW 525 IS GONNA KICKA**
- disabling EBS
- Dear Polaris
- Is this a fair price?
- questions
- CV Boot questions
- Grinding noise at high speed
- 04 700efi creeping forward at idle.
- Front Hood
- Polaris Cyclone wiring diagram
- My 2nd predator
- ATV Pulls ?
- Heel clicker for Scrambler 400
- how do u bleed the brake fluid into the brakes?
- Anyone have any experience with this muffler silencer on their 700?
- Replacing my PTX tires
- 04 400 sportsman shutting down
- How Long Until They Show
- Leaking muffler on TB 250
