View Full Version : Polaris
- 2001 Fan problems??
- Is any one running Mudbugs/Gators/589/MR/BI-TRI?
- What are the biggist tire for a STOCK sportman?
- If you have snokeled your sportsman..
- Help adjusting 98 Sport 400 Rear Brake Pedal
- Whats a fair too good deal on my scrambler?
- Where's the classifieds?
- get the links/pics before they are gone
- questions about my 400 sport
- stuck in reverse
- Polaris Sport 400 top-speed?
- ATV races in Washington MO
- Scrambler gas gauge
- AAEN 470 kit
- '01 Sportsman 500 grease fittings
- Scrambler
- some not so good and exciting news...
- there IS a new polaris sport quad coming!
- reed conversion kit
- 500 Scrambler X.
- MUD BUGS OR MUD RUNNERS?
- Sportsman400
- All of the new rumors for 02
- chain size?????????
- 700 in-line update...
- over charging please help
- 28x12.5x12???
- 2002 Magnum 500 weight increase!
- Is there an OEM parts ordering site on the net?
- HPD Roller Clutch - Installation tips??
- three wheel drive scram help!
- 02 TBOSS kicks a$$
- DG Type 2 Oval Silencer
- Sportsman 700 in-line twin!
- Pitkin, CO Polaris riding...
- Polaris 2002 models on the web now
- anyone running 9" tires or wider on the front of their utility polaris 4x4s please leave a quick response...
- Hot August Nights in Reno NV...
- Scrambler500 4 wheel drive gas/trails??????????
- wanna put four paddleson scram5004x4
- GBC Dirt Devil A/T's?
- Hmmm..Sportsman 700....
- I am really confused!!! Question for Tire experts
- chain size?
- whats the xplorer 250 4x4 like?
- I NEED A NEW CHAIN FAST!!!!!!!!!!
- FTR clutch kit
- can u mx a 400 scrambler 2x4?
- accessory plug on magnum 500
- Brake Question
- Wanted: Used Sportsman
- What would the stroke be on my Scrambler 400???
- Polaris 400 big bore
- 2001 Sportsman 500 HO Service Manual?
- scrambler 500 problems help!!!!!
- Could someone give me the compression ratio formula and procedure?
- A Fair Question?
- ATVers in the Berks/Lancaster/lebanon county, PA AREAs??
- Am I missing something ?
- Do repairs under the extended warranty take longer?
- Fox Shox
- Lessons learned!
- am i the only on that has seen the 500 hpd race quad on atvnews.com?
- hey rick ritter what do you ride
- hey zorro on noengine no blast web site that qaud is fake!
- What is the TrailBoss 325 top speed?
- 34mm carb questions?
- let this one die.....
- do i have to rejet after megamax II and k&n? please help
- does adding mods reduce the retail price of your atv?
- x_scrambler3 were is your web site
- hey mike chero and jack shultz i got a question for you.
- i got a question or two about ridin wheelies and flippin
- wiesco high compression piston in my scram 500
- expolrer 250 engine in trail blazer would it work??
- Getting more POWER out of a Sportsman 500
- Tire size question
- Vamps or Mudrunners?
- Blaster vs Sportsman HO
- Sportsman 500 aftermarket tire question?
- 38 mm carb or clutch kit?
- OUCH!!!
- Advice on Brake Pads ?
- When do you use Low Range on Sportsman?
- Dont Let This Happen to You
- charging system??
- Anybody ever order tires from Rocky Mountain????
- HEADLIGHTS FOR MY SCRAMBABY
- Clutch Removal Tool???
- Scrambler jetting
- Removing Floorboards
- Scrambler 400 clutches
- Are they still good?
- Will scrambler 400 plastic fit a T.B. ???
- Give me your opinion
- More Lighting for Trail Blazer - (pics)
- Staretr Drive Help
- How do you check an oil pump?
- TRAIL BALZER PROBLEM
- Ok all you Montana 4wheelers can I just take my family to the moutains and go for a few weeks on an old jeep trail???
- Xplor FINALLY found out why his scram ate pistons!!!
- Cleaning k&n filter?
- 335 Overtemp
- need a used transmission
- 26x9 BICLAWS and 26x12 GATORS...will the height match?
- will theSportsman400 keep up with Raptor???
- How is Polaris going to keep up?
- changing the spark plug on a 500!! ARGGG
- I need more power for the holeshot
- Anyone been to Fun Wheeler Park? Saturday ride planned!!!
- New Sportsmans - trip planned
- Brakes,Bleeder Screws ???????
- What is a '98 400 Sport worth?
- 2000 400 4X4 GEARCASE?
- questions concerning a 99 sport 400
- Guys, I need your help...
- JET QUESTION ???????????
- Heel Clicker clutch kits?
- spy photos
- a bunch of BS???
- scrambler rear shock failure!!
- Polaris Waterpump Problems.......Need Expert Advice
- What is a good tire for hardpack and sand for scrambler 500 4x4
- CRASH!!!
- Sportsman 400
- Broken CV !!!!! RRRRRRRRRR
- How can you Make a Polaris Scrambler Outrun A new 660 Grizzly???
- Are dented rims a problem?
- Lost my "SNAP" Help me guys!!!
- PRIMARY SPRING COLORS
- Hot Seat GenerationII Pipe, Shims?
- Xplorer 400 bogging when in deep mud holes
- Cheapist place to buy rims and rubber?
- WHY DOES EPI SUCK!!!!!!!??????
- if you own a 99 400 explorer or scrambler//
- What does the RCR Airbox mod consist of?
- Gas Milage for a 99 SC and a 99 SP 500
- Pipe for my trail boss?
- Broken Swingarm--I hate to admit it, but Scramblers won't hold up
- chain poblems,I need help!
- I want to start an ATV'ing club.....
- Where can I get a hitch??
- how to eliminate auto injector on xplorer 400
- What is the deffinition of 25x11x10?
- Loud ticking on recoil side of 01 scrambler 500 2x4. Has anyone found the culprit?
- Oil premix inquiry-->
- 99 400 4x4 scrambler or 01 trail blazer?
- Final jetting question...I promis!
- 500SP list of modifications and some questions for you
- sc500 4x4 vavle adjustment
- hey lurch
- <<SNIP>>
- Operation front tire...... I got some questions
- clutch spring for 400?
- Well, the time has come....
- Are there any other good Polaris forums/sites?
- POLARIS CHAIN TROUBLES.....IS THIS NORMAL?
- HPD Race mod kit 4 trailblazer
- HELP! Can't decide on mud tires!!
- stage one kit?
- Which clutch kit is best?
- Non EBS Clutch On H.O, Anyone try this?
- Scambler front suspension?
- Another clutch question
- Torn Boot
- Bogging
- Does anyone on here go thru spark plugs like candy??
- 2001 sc400 4/4????
- Break in proceedures - new machine?
- POlaris diesel w/ mud tires
- expo 2000 prob
- Anybody tried a dial a jet, from Hot Seat
- Scrambler 400
- 2000 Scrambler 500 4x4 front hubs.
- Air Filter Box
- 400 Pinging when wound out
- blown shock
- Works struts/PEP rear shock, GREAT combo!!!
- A Question for a real polaris expert.!!!!!!!!!!!!
- HD Springs
- FTR web site?
- Looking for parts for my busted A$$ polaris....................
- Sportsman clutch problems
- Polaris Oil
- Polaris Diesel & Mud
- Will the 2002 Sportsman 500 be an orphan?
- LOUD POPING ON TRAIL BOSS ...
- Sportsman Remington vs. Std Sportsman, Difference????
- Best MUD tires
- Sprockets
- HEADLIGHTS FOR A SCRAMBLER 400....
- 96 TRAILBOSS DETONATION (HELP!!!)
- Rim Size???
- Can you post your clutch results?
- Carb adjustments
- Sprocket Alignment
- UNBIASED OPINION 250R vs BANSHEE !!
- Trail Boss 325 Opinion
- Still having gas problems with my 325...Help....
- scrambler vs rubicons/explorers/sportsmans in the mud
- Brought home the Scrambler X Yesturday!
- Which Paddles are Better for Heavier Riders? Straight or Angled?
- Front U joint loose on my Mag 500
- Magnum 500 rear brake clicking????
- Who needs 4wd, I didn't :)
- Snorkels???
- Crazy idea for a scrambler 400 4x4.... look
- Clogged radiators?
- Ticking/clicking/rattle=500 CC camshaft wear?
- How to fix a cracked tranny?
- Scrambler gas guzzler & Hot
- 2002 Sportsman 500 in stock in Minnesota
- Aluminum wheels on a magnum?
- Are there problems putting mudders on a sportsman?
- clutch cover gasket
- need help with trail blazer
- Which Oil To Use In The 2001 Scrambler
- "LOADED" Magnum 500 pictures....finally!
- Valve Cover Bolts
- Sportsman 335 vs. 500?
- Scrambler 500 4x4?????Should I
- Auto's, High or Low gear?
- 3800 miles- - - - new piston ???
- Where can I get Plastic for a Scrambler or Sport?
- SPORTSMAN 700 UPDATE!
- CV boot replacement problem(scram 500)...please help
- Removing the injector...
- Warn Winch Recall!!
- Changed my mind - Four Stroke instead of Two
- Hey All You Arizona Hunters...
- backfiring on exlorer
- mike chero u are in 4 whel atv action
- Hole shot tire sizes how much rougher will the smaller one be?
- What 2-stroke oil to use
- EGT Readings/ HPD HotSeat jets?
- Sport400 4 stroke?!?
- ANOTHER VIDEO..400L-v-250R
- 400 piston noise?
- Air leak... lean midrage... last ditch effort... what to check?
- Hey!!! You fools with the Super-Modded Polaris's....
- Xplorer running horrible...please help!!
- K&N Filter Kit for Sportsman 500 (yes or no)
- colorado atv rental
- 2002 Models?
- VIDEO banshee getting spanked by my 99 sport 400
- HPD Thumb Throttle?
- PA ATV Registratin Law Changes
- Pipe for 1998 Trailblazer. Please Help Little Experience!
- Aftermarket Sportsman front struts ?
