View Full Version : Polaris
- 95 Polaris 400 Explorer
- '93 250 front struts
- FUEL PUMP SCRAMBLER?
- Warn winch/ Polaris Sportsman or Yamaha Kodiak/what to buy.
- October 21st Bubba Rick Ritter both have birthdays!
- Maintenance
- Trip to Irland
- Polaris 700 EFI 2006???
- gas mileage on 2004.5 SP500
- 800 EFI
- pred trany up grade ?
- how to get into racing?
- Snow Plow
- Scrammy ? ASAP
- 1995 sportsman 400 4x4
- muffler on SP. 700 need help
- '02 Polairs Xpedition 425 Engine Problems
- Oil Change
- Upgrades (lots of questions)
- 425 Magnum problems/ cutout HELP!
- 800 break in
- New predator Problem discredits my previous post...
- Trail Boss
- Hey guys, check out this thread and let me know what you think
- scramblerXrated's wheel/tire combo??
- FYI on ITP Wheels & Tires on 330 Trail Boss
- 27x9x12 on stock chrome rims?
- Is there really a hillard adjustment?
- New mudlite
- 2006 X2
- 335 Sportsman squeaky brakes
- arizona bad boys???
- Scrambler 400 / 500 A-arms
- Question For Drag Motor 400
- sp800 wheel balance
- New Prospector Tracks...
- HPD Billet Head
- idahospuds's 03 scrambler tire size???
- Predator Repair Manual?
- valve clearance/idle problem
- 03 SP 700 Brake problem
- Repair stator ?
- 2005 sportsman 500 upgrades??
- 2000 500 sportsman 4x4
- Bigger Than 2" Lift Anywhere?
- Snowmobiles?
- Adjusting chain
- lawn tractor snowplow
- BRP 800 test ride today
- HPD cams?
- Versatrac and other stuff...
- Collet Communicators
- scrambler tire difference?
- Unable to pull start after putting in new cam
- secretive, Predator front brake fix??????
- 05 sportsman 600 fan and warranty question
- 05 Predator Second Gear??? *Glamis inside*
- SP 500 drive belt won't disengage
- Trail tech clamps on pred 05
- C series on 05-06 TLD
- another scrambler clutch ?
- good price for 99 xplorer?
- Scrambler 500 2X4 vs KFX 700
- A-arms and swingarm for pred
- major gas leak on trailboss (help please)
- 2005 sportman 700
- Scrambler 500 engine noise
- Squeel coming from somewhere, need help
- just a few updated pics
- rmk 600 (skidoo question)
- 2005 Sportsman Problem, Need help
- lowering ride height?
- 800 oil consumption
- Slipping ?
- Where go to see 2006 800sp special edition
- Trade?
- sportsman 500 upgrades
- Get a chance to ride the Outlaw!
- how hot does your bike run?
- 800 EFI ??
- 02 Magnum 325 oil light
- Hot cams worth the money
- lifting an 05 sp?
- CLEANING ITP ALUMINUM RIMS???
- wheel spacers on a 05 pred.?
- Changing to a clamp on style filter
- Pipe or CDI
- Team clutch????
- Clutch spring (white)
- Removing old gasket material
- Stiffening up fox rezzies
- 2006 Sportsman 800 EFI S.E.
- need suggestions for scrambler 400 skid plates
- Xplorer 400 4x4 Snorkel
- 800 Power commander Maps
- 2002 Magnum 325 4X4 what kind of oil where?
- Just arrived home with an 05 Pred TLD. 10 .5 hours round trip.
- How many miles can I expect from a 500 HO?
- HELP?/PRED CARB PROB?
- k&n for sportsman 500
- scram 500 cut fenders
- headlight pod
- New piston?
- ITP mud lite XTR radials on 05 Sportsman?
- AWD Not Engaging?
- Scrambler front driveshaft slop on Diff spline??
- Polaris accessories
- Cleaning, detailing, scratch removal, etc....
- '00 SP 335 question about jetting the carb.
- Chain rattling and knocking!
- Stacking headgaskets for scram 400??
- scrambler skid
- Is this normal?
- When to change piston on pred. ?
- any danger running weights that rattle?
- Carb Idle Question.....
- Interesting
- Tires
- Polaris Magnum 325 seems like rear end slipping PLEASE HELP ASAP
- Changing Scrambler Hubs
- changing seals trailblazer 250
- How high can you jump a Scrambler?
- What paddles for RCR 400 sport
- Oil Pump Gear?
- front sprocket
- Help....98 Sportsman 500 rear U-Joint Repair
- getting an 05 pred tle this week, my questions,,,,,.
- new wheeler good price
- pred fan runs alot ?
- GE4x4 in Dirtwheels!
- Tracks
- Help! 05 Sportsman 500 clutching problem
- Predator Tool Kit
- Nerf Bars
- Red hot exhaust
- Sportsman 800 HP and Torque?
- New sportsman owner!!!
- 3 head light mod question
- Got my 04.5 500HO back, quick question?
- Predator Vent tube issue---WHY IS OIL COMING OUT!
- Darn Clutch Polaris 90
- 400 sportsman- clogged radiator fins
- Please Help!!! 01 Polaris 325 Trailboss
- 97 Sportsman 400l chain guard ???
- Trail Boss 330
- 05 TLD PREDATORS GAS TANK SHRUNK!!!
- 2000 trailblazer tires
- Racing a Sportsman 500 HO
- aftermarket pull rope for 400 2 stroke?
- Top Speed of the Predator
- RCR kit
- GETTIN READY 4 RACE DAY
- SP 500 starter rebuild
- 05 700 efi
- 330 4x4 magnum 2003, no nuts (mods)
- '06 Sportsman Steering??
- Stuck rings on Trailblazer 250
- dig this boneheaded blunder.
- connecting rod Big end?
- some pics of scrammy from riding...
- 4.5 5.5 ?????
- Need Stiffer Springs for SP800
- 2005 Sportsman 500???
- Any Better Spark Plug?
- FREE PLAY ON AXLE HUBS ON SPORTMEN
- Dial-a-jet?????
- Predator LE WAY FASTER w/o Quiet core.
- ETA of new Rath Head Pipe?
- 96 sportsman 500
- TLD 05 bolt pattern
- primary clutches
- Pictures of a winch installed on 05 SP500
- 700 EFI problems to watch out for....
- Where is a dealer that will discount?
- Magnum Rear Rack???
- Turf 2wd AWD questions for x2
- Gas mileage for TB250?
- Belt noise problem
- Polaris Outlaw
- 1998 425 mag steering problem help
- any pics of the metal water pump cover for 02 700
- Hard Shifter on SP500
- Bought me a predator.
- lubrication holes on piston
- Transmiision fluid type in 300 xpress
- Sway Bar Disconnect
- 400sp or 500sp
- Scrambler 400 needs more power!
- Rear sproket help
- K&N cleaning
- new 800 problems what should i do help!
- Newbie question, oil injection question
- scrambler 400 pipe
- New SP 800 master cylinder leaking.
- Gas tank reserve?
- Pure Polaris Pipe
- sportsman A-arm guards
- need help with buttons!!!!
- Starer hanging up on SP500
- help please rod connecting torque spec
- Looking for good handguards for the scrambler.
- Is it just the battery?
- Need Advice
- HELP PLEASE!! 500 polaris scrambler
- Improved Sportsman headlight Bulbs
- How do I disconnect the throttle and choke cable?
- How much weight can you drop from the Predator?
- ATV CLUTCH SNOWMOBILE POSSIBLE?
- Race mod hp#'s
- Anyone w/ '05 Predator Service Manual - Jetting ?
- Gear oil in rear and front diff?
- 800 efi Power Cammander module
- 500 HO awd help
- 400/425 Sportsman upgrades?
- trailboss fan wont turn off
- Brush guard bumper
- Mega Power Pipe for the 800
- HAD TO REBUILD THE TOPEND....OUCH$$$
- 2004- 700, which one of the clutch kit out there would you recommend.?
- Snowguy where is that zerk???
- a different approach for scrammy winch install
- 350 or 400? sane different??
- clutch removal for swingarm bearings?
- rear mounted winch
- trail tech computers
- Amsoil 100:1 premix "what do ya think?"
- 400 cracked case what to do?
- Nicholas Racing
- Anyone know how much a stock chain is for a TB?
- trailblazer 250 oil
- pred turns off
- 2004 Sportsman 700 carb doesn't have a fuel gauge.
- Phoenix 200 Hop up parts.
- New HPD Thumb throttle for the predator!!
- 2004 700 Carborated vs. 2005 700 EFI
- What oil are you running in your pred??
- Fuel filter wore a hole through my carb
- Clunk noise from clutch
- 27's on a 03 Sportsman 700
- blew up both clutches on a 2000 600 sportsman
- Best Performance Mod for 2005 Sportsman 500
- 04 SP600 Does my front CV just yank out?
- sp400 cv shaft replacement
- 800 Recall
- help me buy a predator
- Engine Coolant Fluid...
- TRAILBLAZER PRICE
- How to wire a backup light on a 04 700 Sportsman
- Gearcase sealent
- Scrambler 500 X
